#4095742 - 02/10/21 09:50 AM 2005 rear end swap to a 2002, what’s needed?
kyle135 Offline
Loc: Ohio
I plan on doing a moderate-serious build and a rear end with 32 spline axles and 3.55 ratio with a LSD would do wonders. I can’t afford and don’t have the knowledge to rebuild my rear end, what would I need to do to fab a refreshed rear end out of an 05+ into a 2002?
#4095876 - 02/10/21 07:42 PM Re: 2005 rear end swap to a 2002, what’s needed? [Re: kyle135]
dixiebandit69 Offline
5.4 Club
Loc: Texas
That won't work unless you cut and weld a bunch of brackets on the axle housing and the car's frame.
The shocks are moved outward on '03-up models.
You'd probably be best-off having some custom shafts made.
Also, it's 31 spline axles, not 32 (this will make a huge difference when ordering axles).
Lastly, '06 was the first year for the 31-spline axles.
#4096122 - 02/11/21 10:19 PM Re: 2005 rear end swap to a 2002, what’s needed? [Re: kyle135]
why do you need or want to go from 28 to 31 spline axle ?
comming back this fall
#4096128 - 02/11/21 10:46 PM Re: 2005 rear end swap to a 2002, what’s needed? [Re: kyle135]
Davidzq Online   happy
Loc: Seattle, WA
Not worth it.
You would need to weld new shock mounts onto the axle.
You'll also need to use 03+ rims in the rear, and 02- up front. 02- will work in the rear, but will poke out past the fenders.
There are 02- 31 spline axles (which are shorter than the 03+ 31 spline), they were in Towncars ordered with the Limo Prep package...so pretty rare, and probably worn our by the time you find them.
Better off getting custom made axles for your 02- housing.
The rest of the panthers switched in the middle of the 05 model year (December 04 build date).
But really, 28 spline is plenty strong, unless you're doing a serious power build, you shouldn't need to swap.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4096228 - 02/12/21 11:28 AM Re: 2005 rear end swap to a 2002, what’s needed? [Re: kyle135]
if you are hell bent on using stonger axle you can get 28 spline moser axle .
cameron vic is running them on his boosted crown vic .
5 registered (gmerkt, Swamp930, a_d_a_m, Davidzq, Box83), 68 Guests and 99 Spiders online.
bluejay_32 108
JeffBoudah 74
Moby_Vic 73
Old_Guy_Stu 70
Armada Master 54
DudeAbides 50
Dmblanch 46
Ponyguy 43
SocalSam 40
