So it's been a long time since we've updated this thread but we've got a lot completed and really making some headway finally.
The motor (A boss block 5.3 mod motor stroker) was reassembled with ported Trick Flow R heads, new L&M cams specifically for the Trick Flow heads, new ARP 2000 head studs, Cometic 4 layer head gaskets and the motor is back in it's rightful place in the car. (Special thanks to Matt (Car Craft Vic) and Joe (Casper) for helping me get it back in the car!)
Once the motor was back in the car we started mocking up the intake and plenum and checking for hood clearance. We modified the Edelbrock upper intake plenum to clear the hood (had to trim a lot off the top flange and bottom for more fuel rail clearance) Had to put the Accufab 90mm throttle body with one of their quick disconnect clamps on to admire that bling. Gotta love Accufab's product
The Edelbrock intake had the coil on plug bosses trimmed off (as we're going to the Holley smart coils to be able to handle more HP) and was powdercoated black to go with the updated black powdercoated valve covers. We had the modified Edelbrock upper intake plenum polished and ceramic cleared. We also started mocking up the House of Boost dedicated drive system which will hopefully eliminate belt slip. It uses a dedicated 8 rib belt for the blower and switches all the accessories back to 6 rib. We replaced the alternator with a beautiful black Powermaster alternator.
It then went to the fabrication shop (where it still currently sits) for a ton of work! Stripping the entire car of all it's electrical, making new intercooler piping to work with the Edelbrock intake and making the House of Boost dedicated drive system work with our new larger Vortech supercharger. Their system was made for a Procharger brand supercharger so it required a decent amount of modification and spacing to get everything right for the Vortech.
The fun then continued in the interior. We gutted the entire interior to remove all the wiring and all the heating components behind the dash to start fitting the roll cage. While the cage was being put in we also modified the seat brackets for more headroom
It looks like we've hit the quota on pics per thread so more to follow as time permits
BigJon
WOW!!!!!!!!!!!!!!!!!!!!!!!!
Lots of awesome work to your old 92. Love it!
Nice to see you doing well.
-Current: 2001 Crown Victoria P74 -Gone, but not forgotten: 1988 Mercury Grand Marquis 1994 Ford Crown Victoria 2000 Ford Crown Victoria HPP 2004 Ford Crown Victoria LX Sport 2004 Mercury Grand Marquis
BigMerc96 I know nothing Posting Addict
THat is a pretty slick job on the roll cage. Took me a second to even spot the a-pillar tubes in the pic with the dash reinstalled. Is the cage mounted thru the floor and into the frame or just mounted to the body? Seems it could add some stiffness to the frame as an added bonus.
Yeah it's mounted to the frame with standoffs and plates welded to the frame. Should help safety and stiffness
Awesome updates, Chris!
RocktCouch is seriously my favorite Panther build of all time.
_________________________ Pantherless since September 2019 1972 Ford Galaxie 500 | soon to be 7.0L 1978 Ford Fairmont | soon to be 5.0L (Coyote) 1988 Ford Econoline E-350 | Quigley 4x4 | 7.5L 2017 Ford Fusion SE | 2.5L
Rainbowpizza
Loc: SW Florida
Any updates on the couch?
2008 Toro Workman 3100 model number: 07363 with a 3 speed and Fred Flintstone brakes.
Originally Posted By Nassau1969
Bell ill spell the way i want, go clean the train off your lawn.
Originally Posted By Ventana
Old joke: Heaven in Europe is a place where the British are the policemen, the French are the cooks, the Germans are the engineers, the Italians are the lovers and the Swiss run the place. Hell is where the British are the cooks, the French are the engineers, the Germans are the policemen, the Swiss are the lovers and the Italians run the place.
