#4098116 - 02/21/21 01:59 AM
Re: What did you do to your panther today?
[Re: Spartan]
Loc: Shenandoah Valley
I made a new "two cup" cup holder sits on the hump in front of the seat that clears my XM better and still allows a large OD cup to fit. Painted it black and let dry, put black soft rubber pads in the holders cut from an old tool box drawer liner. I also did a little bit of interior detailing, then I put the cover back in place.
Toreador Red 2001 Mercury Grand Marquis with mods ________________ ________WTH? I signed it ... ... and now my name appears in "Fat Sharpie Red " across my screen.
#4098130 - 02/21/21 02:18 AM
[Re: CrystalPistol]
Loc: Oswego, IL
I made a new "two cup" cup holder sits on the hump in front of the seat that clears my XM better and still allows a large OD cup to fit. Painted it black and let dry, put black soft rubber pads in the holders cut from an old tool box drawer liner. I also did a little bit of interior detailing, then I put the cover back in place. Pics?
Sig removed. Read the rules.
My transportation sources: 1972 Green Schwinn Speedster; 1984 Canyon Red Mustang V-6; 2004 Gold Ash GMQ LS Ultimate Edition, (Traded away, sadly); 2004 Black Ranger XLT Flareside; 2019 Turd Brown Fusion Titanium Hybrid Energie.
#4098168 - 02/21/21 07:29 AM
[Re: Spartan]
Fixed it? Maybe.
I noticed an odd and very disconcerting dash/cowl 'clunk' while driving home from work last night. Only present on some bumps, but not all of them, and no rhyme or reason between a minor or major bump. Not the normal Panther noises, definitely something WRONG. Nothing loose in the dash, nothing visible in the cowl. Wondered if the HVAC bits were F'd, but I tested and verified proper function of those.
So, yeah, I was all out of sorts last night and didn't sleep well because of it. Woke up early to double-back to work (it's shift change weekend, lucky me) and thought "wonder if it's some ice rattling around in an area that I can't see?"
So I took it to a local touchless that alleges that they wash with warm water, and paid for the big boi wash. Figured maybe it would knock something loose or melt the ice.
Well, it did the trick! No more clunk.
Unfortunately, all the water that the air dryers didn't get to ended up freezing me IN the car. Inside handle doesn't work now - likely frozen. I had to roll the window down (because somehow THAT still works) and use the outside door handle. Door hinges were frozen and creaky, too.
#vomitcometproblems
#4098308 - 02/22/21 02:22 AM
[Re: Ponyguy]
I made a new "two cup" cup holder sits on the hump in front of the seat that clears my XM better and still allows a large OD cup to fit. Painted it black and let dry, put black soft rubber pads in the holders cut from an old tool box drawer liner. I also did a little bit of interior detailing, then I put the cover back in place. Pics? The ash tray works, but it does securely hold fountain drinks as it wiggles in use. I still have it as a back up.  I know it may not be fancy, but it sure does work well. I might dress it up with some plastic chrome trim. The long "Fin" fits between the two front seats. I made my "compartments" 3-1/4"" x 3-1/4" as you can see, I used some 1/4" thick Luan plywood and some 3/4" thick plain wood, used glue & mostly small brads and/or wood glue. I set it on the hump and then attached two short side ?legs" with screws to the ends to keep it level, the "Fin" keeps it centered. I made the front panel shorter to ease access to my SkyFi XM ... the front shorter side is maybe 3" deep, the rear is 3-1/3" deep, it sits with a very slight lean backwards which is just perfect I find. I painted the wood to color it and seal it, then a clear coat, then after dry I cut two 3-1/4"" x 3-1/4" pieces of Drawer Liner for the cup, bottle, spare change, etc to lay on. To remove or clean, just pick it up. The SkyFi docking station is on a microphone clip attached to the hump to MISS the air bag module under the carpet. I did that in about 2002, it can rock left or right a little, but that's OK.
#4098322 - 02/22/21 06:46 AM
[Re: Spartan]
Started her up and let idle To the fan kicked on,barley got my garage door open from it being frozen.
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 @ 14 pounds Max boost. 458 Rwhp and 441 FPT Currently own: 1979 f250 Camper Special w/460 4 Barrel stock 2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4098586 - 02/22/21 07:19 PM
[Re: Spartan]
Loc: Kansas
Drove it for the first time in about 2 weeks. Started right up and drove fine.
***06 LTC Signature Limited, Silver Birch, 15 Year Old Maps, Movie Theater Audio, Hole-N-Roof, Seat Toaster, TheSunIsMyEnemy Windows ***POTM 06/18 - 10/18***  P.I. zip tube and airbox, Mo's tune, Mach 1 chin spoiler, 4 tone horns, 18" Mustang Premium wheels, UltraGauge, 20% Tint, J-mod, 03 Fogs ***00 Ford Explorer Eddie Bauer, 5.0 HO, AWD, Highly Optioned, J-mod, GlassPacks and "high flow" cats, Kenwood radio, UltraGauge, Spruce Green, 199k. The "Spruce Caboose"
#4098664 - 02/23/21 08:48 AM
[Re: Spartan]
Fixed the illuminated-entry module and the under-dash panel (LH tab was broken).
Edited by Old_Guy_Stu (02/23/21 08:55 AM) Edit Reason: piccy
 1988 CVLX Formal Roof (Love Boat) POTM July 2019 & Aug 2020, 55K E-code lights w/ relays, LEDs w/ switchbacks, 15x8 Ansen slots w/ 255/60 BFG's, Kenwood stereo, various hacks. 1988 CVLX (Destroyer) 1998-2001 driven to death 202K 1988 Squire (Chris Craft) 1996-1998 junkyard rescue driven to death 199K
#4098834 - 02/24/21 08:59 AM
[Re: Spartan]
Loc: Northeast
Grabbed some stuff off a new p7B at picknpull. Antenna to fit my empty bracket, RH rear door panel, new cigarette lighter.
Guy who owned it last was a bit of a whacker, had Wowtao red & blue lights behind the grille.
I grabbed them just to use as party lighting in my house.I usually use red lights after 8pm to preserve natural release of melatonin. Plus RBG lighting is dope.
2001 LX 144k - Lincoln Chaffee's former protective car, RI State Police (sold)
2011 Interceptor 120K, 11k Idle hours - Former Newton, MA patrol car PLZ MP-900 double din 7" touch screen Infinity Reference 6x8 door speakers Alpine 6x9 rear speakers Rockville 10" 800w powered subwoofer Dash Cam w/ backup cam 3.55 Limited Slip, Moog Sway Bar end links and bushings, Mevotech Supreme control arms Ported stock plenum, LED backup and dome lights, RKE
#4098926 - 02/24/21 08:06 PM
[Re: Spartan]
Loc: Kansas
Washed it.
#4098932 - 02/24/21 08:42 PM
[Re: Spartan]
Me too. It was getting a little nasty, and the weather cooperated.
