Page 1904 of 2056 < 1 2 1902 1903 1904 1905 1906 2055 2056 >
#4098116 - 02/21/21 01:59 AM Re: What did you do to your panther today? [Re: Spartan]
CrystalPistol Offline
Loc: Shenandoah Valley
I made a new "two cup" cup holder sits on the hump in front of the seat that clears my XM better and still allows a large OD cup to fit. Painted it black and let dry, put black soft rubber pads in the holders cut from an old tool box drawer liner. I also did a little bit of interior detailing, then I put the cover back in place.
#4098130 - 02/21/21 02:18 AM Re: What did you do to your panther today? [Re: CrystalPistol]
Ponyguy Offline
Loc: Oswego, IL
Pics?
Sig removed. Read the rules.
My transportation sources:
1972 Green Schwinn Speedster;
1984 Canyon Red Mustang V-6;
#4098168 - 02/21/21 07:29 AM Re: What did you do to your panther today? [Re: Spartan]
Fixed it? Maybe.
I noticed an odd and very disconcerting dash/cowl 'clunk' while driving home from work last night. Only present on some bumps, but not all of them, and no rhyme or reason between a minor or major bump. Not the normal Panther noises, definitely something WRONG. Nothing loose in the dash, nothing visible in the cowl. Wondered if the HVAC bits were F'd, but I tested and verified proper function of those.
So, yeah, I was all out of sorts last night and didn't sleep well because of it. Woke up early to double-back to work (it's shift change weekend, lucky me) and thought "wonder if it's some ice rattling around in an area that I can't see?"
So I took it to a local touchless that alleges that they wash with warm water, and paid for the big boi wash. Figured maybe it would knock something loose or melt the ice.
Well, it did the trick! No more clunk.
Unfortunately, all the water that the air dryers didn't get to ended up freezing me IN the car. Inside handle doesn't work now - likely frozen. I had to roll the window down (because somehow THAT still works) and use the outside door handle. Door hinges were frozen and creaky, too.
#vomitcometproblems
#4098278 - 02/21/21 07:43 PM Re: What did you do to your panther today? [Re: Spartan]
ClayBelt Offline
Loc: Leon County
Removed console and replaced carpet. Put a P71 mat underneath for extra sound deadening
#4098308 - 02/22/21 02:22 AM Re: What did you do to your panther today? [Re: Ponyguy]
Pics?
The ash tray works, but it does securely hold fountain drinks as it wiggles in use. I still have it as a back up.
I know it may not be fancy, but it sure does work well. I might dress it up with some plastic chrome trim. The long "Fin" fits between the two front seats. I made my "compartments" 3-1/4"" x 3-1/4" as you can see, I used some 1/4" thick Luan plywood and some 3/4" thick plain wood, used glue & mostly small brads and/or wood glue.
I set it on the hump and then attached two short side ?legs" with screws to the ends to keep it level, the "Fin" keeps it centered. I made the front panel shorter to ease access to my SkyFi XM ... the front shorter side is maybe 3" deep, the rear is 3-1/3" deep, it sits with a very slight lean backwards which is just perfect I find.
I painted the wood to color it and seal it, then a clear coat, then after dry I cut two 3-1/4"" x 3-1/4" pieces of Drawer Liner for the cup, bottle, spare change, etc to lay on. To remove or clean, just pick it up.
The SkyFi docking station is on a microphone clip attached to the hump to MISS the air bag module under the carpet. I did that in about 2002, it can rock left or right a little, but that's OK.
#4098322 - 02/22/21 06:46 AM Re: What did you do to your panther today? [Re: Spartan]
BlackNFast Online   happy
Started her up and let idle To the fan kicked on,barley got my garage door open from it being frozen.
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 and T56 swapped,E85 & 93 tuned.
Currently own:
1979 f250 Camper Special w/460, 650 carb and performer intak
2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4098586 - 02/22/21 07:19 PM Re: What did you do to your panther today? [Re: Spartan]
LTC_Dave Offline
Loc: Kansas
Drove it for the first time in about 2 weeks. Started right up and drove fine.
***06 LTC Signature Limited, Silver Birch, 18 Year Old GPS Maps, Movie Theater Audio, Hole-N-Roof, Seat Toaster, TheSunIsMyEnemy Windows,***POTM 06/18 - 10/18***, Garage Queen
P.I. zip tube and airbox, Mo's tune, Mach 1 chin spoiler, 4 tone horns, 18" Mustang Premium wheels, UltraGauge, 20% Tint, J-mod, 03 Fogs, Bluetooth FM transmitter, Wired back up camera. Dynomax UltraFlows
***00 Ford Explorer Eddie Bauer, Spruce Green, 5.0 HO, AWD, Highly Optioned, J-mod, GlassPacks and "high flow" cats, Kenwood radio, UltraGauge, 200k.
***94 Ford Ranger XLT, 3L, 5 Speed. 82k. 01 Mustang wheels. Easy mods and repairs. Daily
***02 Honda Accord, 213k. VTEC YO
#4098664 - 02/23/21 08:48 AM Re: What did you do to your panther today? [Re: Spartan]
Old_Guy_Stu Offline
Fixed the illuminated-entry module and the under-dash panel (LH tab was broken).
Edited by Old_Guy_Stu (02/23/21 08:55 AM)
Edit Reason: piccy
#4098818 - 02/24/21 08:39 AM Re: What did you do to your panther today? [Re: Old_Guy_Stu]
bluejay_32 Offline
Loc: wny
Yesterday after my dentist appointment I filled it up then took it over past Delta Sonic, where I saw the lines weren't too long, so I went through for the first time in months. The clean didn't last long as I had to drive home, where I spun the wheels throwing [censored] up on it backing into the driveway.
Originally Posted By BigNSlow
Stop watching Scotty Kilmer, he reverses evolution.
#4098834 - 02/24/21 08:59 AM Re: What did you do to your panther today? [Re: Spartan]
VoodooChild Offline
Loc: Northeast
Grabbed some stuff off a new p7B at picknpull. Antenna to fit my empty bracket, RH rear door panel, new cigarette lighter.
Guy who owned it last was a bit of a whacker, had Wowtao red & blue lights behind the grille.
I grabbed them just to use as party lighting in my house.I usually use red lights after 8pm to preserve natural release of melatonin. Plus RBG lighting is dope.
Signature removed for excessive length; read the rules
#4098926 - 02/24/21 08:06 PM Re: What did you do to your panther today? [Re: Spartan]
LTC_Dave Offline
Loc: Kansas
Washed it.
#4098932 - 02/24/21 08:42 PM Re: What did you do to your panther today? [Re: Spartan]
Old_Guy_Stu Offline
Me too. It was getting a little nasty, and the weather cooperated.
#4098958 - 02/24/21 09:28 PM Re: What did you do to your panther today? [Re: Spartan]
Washed it, drove it down to Holmes County to check out a bike route for later this year.
#4098968 - 02/24/21 09:43 PM Re: What did you do to your panther today? [Re: Spartan]
ClayBelt Offline
Loc: Leon County
Worked through some tuning with Marty and put a ranger shift boot in it
#4099072 - 02/25/21 01:49 PM Re: What did you do to your panther today? [Re: Spartan]
Huhnigan Offline
vonirkinshtine
Loc: LKN, NC
Took it to Lowes for some drywall.
2004 Crown Victoria LX Sport. 3rd owner (I personally knew both previous owners).
Originally Posted By EMTSteve
I'm not with Law Inforcment
Moderator:  Chaplian, jmlock, Ryan, The_Punisher
0 registered (), 85 Guests and 7 Spiders online.
