Page 2 of 2 < 1 2
#4101024 - 03/08/21 01:33 PM Re: Are all 5.0L EGR valves the same? Code 34. [Re: Bluwaggo]
Bluwaggo Offline
Loc: NC
They was my first thought as well--remove the auto temp control and replace it with a tube splitter/adapter. Unfortunately, the one I ordered is too shallow to allow the sender to thread in. Maybe I just need to make something out of brass fittings...
75,000 mile 1989 Crown Vic LTD wagon, answers to "Marge".
#4104342 - 04/07/21 02:39 PM Re: Are all 5.0L EGR valves the same? Code 34. [Re: Bluwaggo]
Bluwaggo Offline
Loc: NC
A backyard landscaping project has stolen a lot of my spare time since this problem developed, but I can finally make an update.
Virtually anything that could have gone wrong went wrong.
- The temp sensor is the wrong one (two wire vs my one wire).
- The very expensive custom brass rig I built to go in place of the auto temp sensor keeps the sensor just enough out of the flow that I don't get an accurate reading and I need to splice the upper rad hose. Otherwise, it looks like the coolant is 100* at operating temp rendering the gauge effectively worthless.
- The copper splitter I bought technically does install just fine but I can't attach anything to it. It needs extensions or 45s or both or something. So I just installed the new oil PSI sensor, which thankfully is the correct one, back into the port. I would have installed the gauge instead, but the sender won't fit in that space without help.
All that mess said, I idled the car for at least 15 minutes, it definitely came up to temp, and there was no RCELOD.
Page 2 of 2 < 1 2
0 registered (), 27 Guests and 207 Spiders online.
CrystalPistol 258
bluejay_32 161
Old_Guy_Stu 109
a_d_a_m 71
Moby_Vic 66
Dmblanch 60
Ponyguy 57
DudeAbides 46
Danger2manifold 35
