Page 2 of 3 < 1 2 3 >
#4103048 - 03/27/21 04:14 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
BrainIsSlow Offline
Loc: Arizona
Just purchased CHE performance upper/lower trailing arms and installed a spectre throttle body spacer. I still need to reset my ECU so it can adjust for the spacer.
#4103050 - 03/27/21 04:15 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
BrainIsSlow Offline
Loc: Arizona
#4103052 - 03/27/21 04:16 AM Re: How much HP can I get out of a N/A 4.6? [Re: TheCableGuy]
BrainIsSlow Offline
Loc: Arizona
I'm thinking nitrous. Still looking for a good dry shot kit to buy
#4103058 - 03/27/21 09:00 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
2004_p71 Online   content
Originally Posted By BrainIsSlow
Are those jet performance throttle body any good? And at what do I need to do to avoid a check engine light when swapping my intake parts?
you may need a tune
comming back this fall
#4103060 - 03/27/21 09:02 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
Do I absolutely need to get them degreed? What are the consequences of not doing so?
no but you will most likely have one bank fighting the other bank because the cam centerline arent installed strait up.The engine will run but not on top of the game.
Just think if you had a leg shother than the other one by an inch or two . You could still walk and maybe run decently but it would be far from good .( sorry that is the only axample I could think of lol )
#4103062 - 03/27/21 09:07 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
If I get the cams before the headers, will I still get an increase or will I lose power? I don't have a problem doing things out of order just so long as they don't send me in the opposite direction.
Cam do not add power per say but move the powerband higher . You will be making power in the higher rpms where the stock cam didnt have enough duration to fill the cylinder with air . Going with a radical cam profile will kill too much low end torque and the rest of the components and use of the car must match the cam profile.
#4103064 - 03/27/21 09:10 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
looks like you are going all over the place with your project .
#4103066 - 03/27/21 09:11 AM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
the spacer will do fu,,all
#4103136 - 03/28/21 12:38 AM Re: How much HP can I get out of a N/A 4.6? [Re: 2004_p71]
BrainIsSlow Offline
Loc: Arizona
Pretty much
#4103138 - 03/28/21 12:39 AM Re: How much HP can I get out of a N/A 4.6? [Re: 2004_p71]
BrainIsSlow Offline
Loc: Arizona
I figured.
#4103140 - 03/28/21 12:43 AM Re: How much HP can I get out of a N/A 4.6? [Re: 2004_p71]
BrainIsSlow Offline
Loc: Arizona
What can profile should I consider that won't effect my low end performance?
#4103142 - 03/28/21 12:45 AM Re: How much HP can I get out of a N/A 4.6? [Re: 2004_p71]
BrainIsSlow Offline
Loc: Arizona
Is there anything I can do to delete the EGR? Seems counter productive to be sucking so much carbon into the intake...
#4103182 - 03/28/21 06:23 PM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
ClayBelt Offline
Loc: Leon County
XE262AH is the most I’d do without affecting low end. EGR, you’ll need to make a block off plate as well as take care of the vacuum lines for it. I snapped off the two plastic ones for the EGR at the rubber booth and melted the plastic shut with a lighter. It’ll take a tune to get rid of the check engine light though
#4103196 - 03/28/21 08:34 PM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
You should research what does the egr then
#4103202 - 03/28/21 09:25 PM Re: How much HP can I get out of a N/A 4.6? [Re: BrainIsSlow]
TheCableGuy Offline
Loc: Far Northwest AZ
Honestly man, not to be “that guy” well low and behold here I am, the search function is an amazing gift. All of your questions.. there is literally so many posts on. Just sayin..
2010 P7B 150K. 11K hours. 3.27, RKE, Cruise, Ported stock plenum, JMod, ADTR sway bar, KYB rear shocks. DIY Headlight harness upgrade, with projector retrofit: Mini H1’s.
Previous rides:
3 registered (DudeAbides, MurkyMerc, Rootintootin), 77 Guests and 106 Spiders online.
Moby_Vic 76
JeffBoudah 74
Old_Guy_Stu 69
Armada Master 54
DudeAbides 51
a_d_a_m 49
Dmblanch 46
Ponyguy 43
SocalSam 38
