#4102532 - 03/22/21 07:17 PM Air Conditioner From Fine To Dead Within An Hour
LegoFlats Offline
Loc: Pennsylvania
I am making a very general inquiry to see if there are common problems which might cause this issue.
2008 CVPI which is completely stock. The HVAC system, to my knowledge is the same as installed from the factory. Went out for a 15 minute lunch and ran the car AC. No trouble, no odd noise. Inconsistent idle, but that's a work in progress repair. Shut the car off.
Came back out after work to find that the entire HVAC system no longer works. When engaged on the climate control, I can hear coolant flowing. Aside from the BJB blower relay, is there any other common problem which could cause this?
2008 White P71 | Former Millbrook, OH City Patrol Unit 15 | Yellow/Amber Visor Lighting For Roadside Utility And Freelance Security Work | One Deer Collision | My Brother's Personal Uber, I Guess
#4102534 - 03/22/21 07:36 PM Re: Air Conditioner From Fine To Dead Within An Hour [Re: LegoFlats]
bluejay_32 Offline
Loc: wny
Are you saying the fan is dead, or it stopped blowing cold? Does the blower work on high?
CVN POTM - February 2019 joy
#4102536 - 03/22/21 08:08 PM Re: Air Conditioner From Fine To Dead Within An Hour [Re: bluejay_32]
LegoFlats Offline
Loc: Pennsylvania
Absolutely no activity at all from the HVAC system. Can't hear it run, no air is flowing.
#4102550 - 03/22/21 09:52 PM Re: Air Conditioner From Fine To Dead Within An Hour [Re: LegoFlats]
bluejay_32 Offline
Loc: wny
According to the BOK, it looks like fuse 101 is the blower relay feed.
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=1920429#Post1920429
That would be the first place I would check. I've also found that when blower motors are going bad if you give it a whack it'll start back up and run sometimes, just make sure you do it with it turned on. I'd say the motor itself or the fuse are more likely than the relay.
If you can switch the relay with another one of the same size and (looks like the rear defroster one is the same from that diagram, but I may be wrong), you can rule that out as being your problem.
Edited by bluejay_32 (03/22/21 09:55 PM)
#4102598 - 03/23/21 10:47 AM Re: Air Conditioner From Fine To Dead Within An Hour [Re: LegoFlats]
a_d_a_m Online   drunk
I would've guessed it's the blower motor resistor, but when those fail, they usually default to working on the highest speed setting...
#4102636 - 03/23/21 01:13 PM Re: Air Conditioner From Fine To Dead Within An Hour [Re: a_d_a_m]
Danger2manifold Offline
Loc: Little Poland, CT
Yes, I believe they do that with a relay or something. Fuse is a good place to start, and stupid cheap to boot
Current Panther:
Past Rides:
#4102694 - 03/23/21 07:20 PM Re: Air Conditioner From Fine To Dead Within An Hour [Re: bluejay_32]
LegoFlats Offline
Loc: Pennsylvania
It was indeed fuse 40A 101. Took it out to investigate, didn't look burned, so I reinserted. AC fired right up.
On the list of enduring problems with this car atm, I am glad AC isn't one.
Thank you very much!
1 registered (a_d_a_m), 46 Guests and 101 Spiders online.
Old_Guy_Stu 108
bluejay_32 102
Dmblanch 67
a_d_a_m 60
GM_Guy 42
Moby_Vic 36
Ponyguy 30
Rootintootin 28
Tenevic_P71 28
