#4104004 - 04/05/21 12:32 AM Long Tubes Header - EGR Mod.
99siggy Offline
Loc: Houston, Texas
I'm installing a set of BBK headers (96-04 Mustang) on my 1999 LTC. I have removed the stock dual exhaust including the manifolds.
I'm trying to solve the problem with the EGR. Specifically an EGR tube with the DPFE tubes, long enough to reach the driver side EGR port on the headers (stock location is on passenger side) and back to reach the EGR valve.
Has anyone successfully solved this problem?
Thank you,
David
1999 Lincoln Town Car Signature Series.
MZT. 3.73 w/TrakLok. Dual Exhaust. 21mm Rear w/ ENS Kit. Bilstein HDs. New Arnott Air Springs/Compressor. 200A Alternator w/ Big 3.
4-Note Caddy Horn. A-Pillar Mounted Tach. Double-Din w/ Sound System. 5500k HIDs. Interior LED Swap. Husky Floor Mats.
#4104324 - 04/07/21 12:50 PM Re: Long Tubes Header - EGR Mod. [Re: 99siggy]
I think some people ended up using flexible tube that is made of natural gas , apparently the coupling are the same size .
#4104604 - 04/09/21 07:21 PM Re: Long Tubes Header - EGR Mod. [Re: 99siggy]
dixiebandit69 Offline
5.4 Club
Loc: Texas
The gas tube will work for later model Panthers, but since your car has the DPFE sensor separate, I think you'd be best off modifying your existing tube.
#4105098 - 04/13/21 10:25 PM Re: Long Tubes Header - EGR Mod. [Re: 99siggy]
ClayBelt Offline
Loc: Leon County
I deleted the egr
2 registered (Traffic22, Dmblanch), 64 Guests and 315 Spiders online.
bluejay_32 159
Old_Guy_Stu 88
CrystalPistol 80
a_d_a_m 77
TheCableGuy 57
DudeAbides 53
Ponyguy 49
Moby_Vic 47
Bangster 46
RF_Overlord 46
