#4095936 - 02/11/21 12:26 AM What gear ratio is best for me?
young831 Offline
Loc: Santa Cruz County, California,...
I know this has been done to death;
I have a 3.27 open now, and I'm thinking about stepping up to 3.55 or 3.73. My goals are I want it a little more punchy in town, I might end up upgrading the Watts linkage and other suspension components and towing, but that's only a possibility.
The big thing though is that I will be cruising pretty fast on a highway, and when I floor it from there, I will be going too fast for it to downshift into third, so I end up having to climb a mountain up from 1700 RPM or so in fourth, where if I had floored it at a lower speed, it would have downshifted into third, and then a second or two later bang back into fourth at an RPM high enough to be in the power band. I'm interested in increasing the RPM in fourth when I'm cruising at a good clip to the point where I'm in the power band and not climbing a mountain.
I also know the vic is heavy, old fashioned car, so I'm ok with taking an MPG hit, but it's unclear to me from searching this forum how much of a hit I will take when cruising at a high highway speed, 75-85 or so.
So to sum up, Given the use case I described, do you think it's worth sticking with 3.27, or stepping up to 3.55 or 3.73? And sorry for being probably the 500th person to ask.
2009 P71, 6 years as a NorCal cop car, 5 years as a NorCal cab, and a few months with me.
Other vehicles I've driven a while:
2002 Honda Accord Coupe EX-V6
2008 BMW 328i SULEV
2011 Smart Fortwo Pure
#4095948 - 02/11/21 07:14 AM Re: What gear ratio is best for me? [Re: young831]
ClayBelt Offline
Loc: Leon County
I went from 2.73 to 3.55, highway mpg dropped about 3mpg, from 28 to 25. 3.27 to 3.55 isn’t worth it, but 3.73 would probably be a 2mpg hit since it’s a 2 step gear ratio change.
#4096076 - 02/11/21 08:11 PM Re: What gear ratio is best for me? [Re: ClayBelt]
young831 Offline
Thanks, that's good info. I'm wondering what your typical highway speed is? I have to imagine that the MPG hit is going to be much different at 65 vs at 80.
2008 BMW 328i SULEV
#4096086 - 02/11/21 08:56 PM Re: What gear ratio is best for me? [Re: young831]
ClayBelt Offline
Loc: Leon County
I have a manual, going about 80 it’s 27mpg. When I had the auto it was more like 25mpg at 75mph, and with the factory 2.73 gears it was 28mpg at 70mph because I was hypermilong the [censored] outta it cause I wanted to make the run from Tallahassee to Fernadina Beach and back on one tank. Now some of that may just be because I was going different speeds, but at the end of the day a lot of it boils down to how much you mash the skinny pedal.
#4096112 - 02/11/21 10:05 PM Re: What gear ratio is best for me? [Re: young831]
Dont fear the gear , go 3,73 !
comming back this fall
#4096526 - 02/14/21 01:27 AM Re: What gear ratio is best for me? [Re: young831]
young831 Offline
Thank you both for the information. I'll probably end up swapping the 3.27 open I have now for a 3.73 limited slip.
2008 BMW 328i SULEV
#4096556 - 02/14/21 07:50 AM Re: What gear ratio is best for me? [Re: young831]
excellent
#4096590 - 02/14/21 12:38 PM Re: What gear ratio is best for me? [Re: young831]
CrystalPistol Offline
Loc: Shenandoah Valley
If I had 3.27 now and was going to re-gear, I would not do it for just 3.55s Only if happy with the 3.27 and I had to replace the R&P due to noise and I got a great deal on the 3.55 set new. I'd go 3.73s at least, or 4.10s unless I was looking to add "leg length", then I'd go for 2.73s. If I had 3.55s, I'd just keep them or jump to 4.10s.
Back when Mopars had the 8-1/4 removable hogshead, my 340 Swinger had one. I had more than one from salvage, 3.23 from a late '50s 300, the car's 3.91 oem set, and a fun filled 4.88 set from a wrecked old Dodge that had a pair of carbs that we found in a junk yard. Each had it's own yoke too. Usually I ran the 3.23 going to college, sometimes the 3.91s, 4.88s were pretty deep though. One Friday I slipped the 4.88s into our '68 Satalite Sport Wagon, 383 4bbl, it was a fun cruise night for I and some buddies but come Monday, I put the car's oem 3.23s back in while she was at work.
I kept a few gaskets for both axle ends and the center hung up, and usually I would reuse the fluid after a long slow drain through a collander (screened bowl). None of my gearsets were posis, I just set snubbers close with longer bolts and wood spacers ... and made other adjustments in air shocks left to right on my Swinger ... but on the wagon I adjusted the overload leaves Dad had put on it to plant the right with those 4.88s, I just removed the left one. Mopars had long leaves but the long part was at the rear, the front part was a really short, almost solid like stack.
#4097420 - 02/18/21 11:21 AM Re: What gear ratio is best for me? [Re: young831]
Big_Pimpin Offline
Loc: NC
8 3/4 mopar axle had the drop out pumpkin.My mopar roots wouldn't let that slide lol.
I had 2.73 in my GM when I bought it.I don't drive highway often but wanted more get up and go.I went to a 3.55 limited slip for better low end and still some top end.
What size tire are you running? A shorter tire gives you a little more effective gear ratio if you want to see what it would feel like.
I have the same kickdown issue past a certain speed with the 3.55 gears.You can always grab the shift lever and drop it into second when you need to.
#4105926 - 04/22/21 06:03 AM Re: What gear ratio is best for me? [Re: young831]
BrainIsSlow Offline
Loc: Arizona
What company makes the best diff parts?
#4105946 - 04/22/21 09:38 AM Re: What gear ratio is best for me? [Re: young831]
2008interceptor Offline
Loc: Pennsylvania
You could probably have the car tuned to kickdown as you wanted. Probably easier on the trans than a manual pull down into 2nd.
5 registered (Dmblanch, Freddy12189, 01boatman, SlimOne, lance54r), 82 Guests and 139 Spiders online.
bluejay_32 108
JeffBoudah 74
Moby_Vic 73
Old_Guy_Stu 70
Armada Master 54
DudeAbides 50
Dmblanch 47
Ponyguy 43
SocalSam 40
