#4103976 - 04/04/21 08:09 PM Shorty headers for our cars?
Big_Pimpin Offline
Loc: NC
Do the mustang shorty headers work on our cars? BBK as an example. Most of the other brands for 4.6 2v are either not around anymore or more expensive.
The cost of long tube headers is up there and I know they would make more power. As a compromise with my wallet I am wondering if mustang shorty headers would work or do they have other inherent problems?
We swapped a 2v motor in a mustang at the shop I work at and those factory manifolds are begging for any improvement.
I tried the search function but only found threads with long tubes.
THANKS
#4104062 - 04/05/21 12:45 PM Re: Shorty headers for our cars? [Re: Big_Pimpin]
Davidzq Offline
Loc: Seattle, WA
Two things.
First, no, they will not fit.
Shorty's would point your exhaust directly at the panther frame.
SOME Mustang longtubes can be made to fit by denting the pipes for clearance.
Second, shorty's aren't worth it anyway. They provide almost no gain over the stock manifolds.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4106508 - 04/27/21 07:45 AM Re: Shorty headers for our cars? [Re: Big_Pimpin]
musclemerc Offline
Loc: MS
^^^^ You Sir are 100 percent wrong!!!
OP, yes shorty headers from a mustang will fit! You will need a Mustang H or X pipe to match the collector. The mid pipe will need to be extended 6" to get to the rear half of the system. The motor mounts will need to be shimmed 1/4", and the steering shaft will need some grinding.
I've installed 10 sets of Mustang shortys/midpipes on Panthers over the past years
As far as gains are concerned I personally dynoed and saw an 18HP/20TQ gain so the claim of "no gains" is just wrong.
Yes LT's will yield more power/TQ, but not the 30 HP/TQ everyone claims. HP/TQ on a NA car with LT's only gain 26-28 HP/TQ
19lbs of boost
GT500 TVS Powered Marauder
#4106552 - 04/27/21 02:00 PM Re: Shorty headers for our cars? [Re: musclemerc]
Packman Offline
Loc: Joisey
That's enough to feel with the butt dyno; and in my book, worth the hassle to install (also the increased mpg).
Question: what's the fitment like with the Mustang H-pipe? I know this is an apples to oranges comparison; but I had fitment issues with the BBK fox body h-pipe I put on my '86 CV. I hope it's not the same with the Whales.
2005 Grand Marquis base model (analog dash and a cassette player *sigh*) Mods: SW long tubes, full 2.5" exhaust (cats and dynomax 17749 muffs), and K&N CAI
1986 Crown Vic Built 351W and AOD, BIG brake swap, 3.73R&P, etc....
#4106636 - 04/28/21 07:33 AM Re: Shorty headers for our cars? [Re: Big_Pimpin]
musclemerc Offline
Loc: MS
The midpipe fitment is good. As I stated earlier you will need to extend the mid section 6". I usually ad a pair of Magnaflow high flow cats to make up the difference in length.
Just an FYI you will need a tune to take advantage of any free flow exhaust doesn't matter if its shortys or LT's.
Check my old threads for pics and writeup
19lbs of boost
#4106648 - 04/28/21 11:31 AM Re: Shorty headers for our cars? [Re: Big_Pimpin]
85GT Offline
Loc: NYC
And while shorties don't peak power/torque like long tubes when they hit their design rpm, shorties do raise for the most part the whole power/torque curve. Above LTs when not at in the LTs peak range.
08 CVPI
85 Mustang GT w/4R70W
91 Caprice
95 Caprice
3 registered (Scuba_Steve, CarMon, alumarine), 108 Guests and 9 Spiders online.
