#4106758 - 04/29/21 02:03 PM radiator cap blowed up!!!
bigdaddyd Offline
Loc: Austin, Tx
new one for me. wife went to work car over heated, limped home. later i checked the tank and empty. filled up with water and put cap back on. stated up fine, ran for a while, turned on the ac and didn't hear fan kick on. temp still looked ok and thought its cool out today, maybe it wasn't warm enough yet. put the car in gear, needle started to rise. car is running and i popped the hood hoping to see a coolant leak and right as i went back to turn ac off the cap blew off and a coolant volcano flowed out the front! crazy!! lasted about 10 seconds! covered the whole engine! never seen a cap just blow off!! HELP!!!
#4106760 - 04/29/21 02:28 PM Re: radiator cap blowed up!!! [Re: bigdaddyd]
bigdaddyd Offline
Loc: Austin, Tx
went out and started the '07 and let it idle for a little bit then turned on ac. about 10 seconds the fan kicked on. refilled '09 with water and started up. idled fine. turned on ac and no fan. will be putting new fan on today.
#4106764 - 04/29/21 02:48 PM Re: radiator cap blowed up!!! [Re: bigdaddyd]
bigdaddyd Offline
Loc: Austin, Tx
still don't get why the cap blew off? thought it was supposed to bleed off? new cap too????
#4106770 - 04/29/21 05:03 PM Re: radiator cap blowed up!!! [Re: bigdaddyd]
Before you run out and get a new fan, check the fan relay in the BJB (next to the battery). A new relay is a lot cheaper than a whole new fan assembly.
#4106778 - 04/29/21 05:41 PM Re: radiator cap blowed up!!! [Re: RF_Overlord]
bluejay_32 Offline
Loc: wny
Fan relay is not in the junction box, it's on the shroud next to the fan itself, and is a common failure point.
Edited by bluejay_32 (04/29/21 05:42 PM)
Edit Reason: I really don't like hitting the "x" key if I can substitute something different
CVN POTM - February 2019 joy
#4106804 - 04/29/21 08:33 PM Re: radiator cap blowed up!!! [Re: bigdaddyd]
Thanks for the correction, bluejay. I did notice (at least on my 2004) that there's a fan fuse (F102, 50A) in the BJB...that must have been what I was thinking.
#4106808 - 04/29/21 08:56 PM Re: radiator cap blowed up!!! [Re: bigdaddyd]
CrystalPistol Offline
Loc: Shenandoah Valley
Originally Posted By bigdaddyd
... etc ... the cap blew off and a coolant volcano flowed out the front! crazy!! lasted about 10 seconds! covered the whole engine! never seen a cap just blow off!! HELP!!!
I had one or two returned at Advance, but it was rare, they were Stant too. Looked like the cap cracked across the threads and just let go, kind of like a plastic water hose bib nut that's been tightened too many times or just "was it's time" maybe. I know guys who worked there for years whom said they had never seen it.
#4107736 - 05/06/21 01:25 AM Re: radiator cap blowed up!!! [Re: bigdaddyd]
bigdaddyd Offline
Loc: Austin, Tx
all in 1 assembly from autozone fixed it!
1 registered (Old_Guy_Stu), 36 Guests and 79 Spiders online.
Old_Guy_Stu 111
bluejay_32 103
Dmblanch 49
RF_Overlord 40
GM_Guy 39
Tenevic_P71 32
Moby_Vic 32
2008interceptor 29
AlleyG 29
