#4106528 - 04/27/21 09:22 AM 2004 EATC System Swap
Rainyp71 Offline
Loc: North Carolina, USA
Hey guys,
I pulled the entire EATC system from an 04 lx. The entire dash harness, all the temp sensors and sunlight sensor, the EATC head, the entire airbox assembly, the entire vacuum system and harness, etc. Does anyone have the electrical diagrams from the shop manual for the EATC head/EATC system? I have been using the old 2vmodular EATC swap documentation, but he was using a system from a 2000. Im assuming most info is the same, but any proper documentation will be a big help.
Best regards,
Rob
2000 P71 Crown Vic former Gordonsville, VA Police Wrecked @ 200,199 Miles - All fixed! Currently 247,000 Miles
GMAX As-05 tires, custom trunk false floor, autometer tach, Sony Double DIN Head Unit, KYBs all around.
#4107280 - 05/02/21 11:41 PM Re: 2004 EATC System Swap [Re: Rainyp71]
P_Weston Offline
Cynical Bastard
Loc: Reno, Nevada
I did the same swap using 2VModular's directions. I'm pretty sure that 2000 was it's own unique year as far as EATC components went. If I'm not mistaken you needed to pull from similar year cars in the ranges of 98-99, 00, 01-02, 03-04 and 05+? I'm absolutely sure the wiring differences from 00 to 04 are significant. I wish I could help but I only have the Ford wiring book on 2000 year CV/GMQ, nothing regards the car you pulled from.
2000 Mercury Grand Marquis GS "Dewgong"
#4107362 - 05/03/21 04:41 PM Re: 2004 EATC System Swap [Re: P_Weston]
Rainyp71 Offline
No worries! Thanks for the reply anyways! I literally just got in my copy of the 2004 wiring manual. By the time I'm done this car will be a hodgepodge, but the engine will be completely independently controlled so I just need to figure out what needs to be done to get the EATC system running on its own. Because its pre-CAN I can't imagine it will require too much craziness.
4 registered (GrumpMarky, Rootintootin, magic, 1 invisible), 65 Guests and 236 Spiders online.
CrystalPistol 209
bluejay_32 172
JeffBoudah 61
Moby_Vic 59
Ponyguy 57
a_d_a_m 54
Dmblanch 53
Bangster 40
TheCableGuy 39
