#4107346 - 05/03/21 03:33 PM Leaking Rightside Shock Absorber Bellow.
thephnx39 Offline
Loc: Texas
My bellow I guessed cracked or punctured and leaked out fluid, my question is was fluid goes inside the bellow and is it just a simple switch out to replace or is it more complicated?
2006 Grand Marquis
2006 MERCURY GRAND MARQUIS LS
#4107372 - 05/03/21 04:52 PM Re: Leaking Rightside Shock Absorber Bellow. [Re: thephnx39]
RF_Overlord Online   content
That bellows is simply a dust shield to keep dust and dirt away from the piston shaft. If you have an oil leak, the seal has failed and the entire shock need replacement.
#4107394 - 05/03/21 06:47 PM Re: Leaking Rightside Shock Absorber Bellow. [Re: thephnx39]
thephnx39 Offline
Loc: Texas
So the Shock is probably cracked leaking the fluid? If I replace shock will the fluid be in New Shock or will it have to be added? And will it require any calibration after installation? Thank you.
#4107400 - 05/03/21 07:47 PM Re: Leaking Rightside Shock Absorber Bellow. [Re: thephnx39]
CrystalPistol Offline
Loc: Shenandoah Valley
Shocks normally get replaced in pairs if used much. If new, then if just one leaked I'd either replace the one with exact same, or more likely, replace both on that axle. If high miles, then the whole set. New shocks come prefilled and are sealed.
You don't want a new one on one side and a well worn used one on the other side any more than you want a leaking one on a side with a just serviceable one on the other side.
Problems huh? Then Read THE Book. Signed: A natural borne "neanderthal".
Toreador Red 2001 Mercury Grand Marquis .... with some minor mods. joy
#4107416 - 05/03/21 09:49 PM Re: Leaking Rightside Shock Absorber Bellow. [Re: thephnx39]
2008interceptor Offline
Loc: Pennsylvania
Is this a front or a rear and if front are you getting a quick strut which would come with new springs? You likely wouldn't need an alignment with rears. Possibly not with fronts if just the strut cartridge itself is changed. Though an alignment check which can be free or low cost would be worth it to be sure.
#4107420 - 05/03/21 10:17 PM Re: Leaking Rightside Shock Absorber Bellow. [Re: thephnx39]
thephnx39 Offline
Loc: Texas
Rear shocks
4 registered (a_d_a_m, GrumpMarky, 2 invisible), 74 Guests and 206 Spiders online.
CrystalPistol 210
bluejay_32 172
JeffBoudah 61
Moby_Vic 59
Ponyguy 57
a_d_a_m 54
Dmblanch 53
Bangster 40
TheCableGuy 39
