#4111626 - 06/04/21 01:33 AM Can Anyone ID This Driveshaft
Traffic22 Offline
Loc: CA
Wondering is this is one of the Alcoa MMC/MMX driveshafts?
https://sfbay.craigslist.org/eby/pts/d/oakland-crown-victoria-aluminum/7322530994.html
If so, can I swap this into my 2011? I’ve been trying to figure it out, but not certain. Chris’s driveshaft swap article on ADTR is good, but talks primarily about swapping into a civilian car. I have a P7B.
#4111628 - 06/04/21 01:40 AM Re: Can Anyone ID This Driveshaft [Re: Traffic22]
Traffic22 Offline
Loc: CA
I apologize for the premature post, just saw this in the ADTR article.
“ Note: An MMC/MMX driveshaft can be identified by one of a few different ways based on feedback from several CrownVic.net members:
– MMC/MMX has pink and green stripes running around the shaft while all others have pink/blue/orange stripes.
– Large letters “POLICE” with small black print with the letters “MMC””
Based on photos it is not a MMC/MMX
#4111642 - 06/04/21 08:23 AM Re: Can Anyone ID This Driveshaft [Re: Traffic22]
Davidzq Offline
Loc: Seattle, WA
That is a standard aluminum driveshaft.
A MMX driveshaft would be direct swap into any P71/P7B
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4111668 - 06/04/21 01:35 PM Re: Can Anyone ID This Driveshaft [Re: Davidzq]
Traffic22 Offline
Loc: CA
I saw the ID guide late. I'll keep searching for the MMX. Thanks.
Good to know it is a direct swap. Thank you for the info, it is appreciated.
#4111704 - 06/04/21 09:45 PM Re: Can Anyone ID This Driveshaft [Re: Traffic22]
2007CrownVic Offline
The cragslist one is a high price for something that's usually $20-$50 or so at junk yards.
#4111950 - 06/08/21 11:59 AM Re: Can Anyone ID This Driveshaft [Re: Traffic22]
shipracer Offline
Loc: California
I had to go to multiple junkyards across a month or two to finally find one. When I found it I wasn't even sure it was it.
The welds on my MMC look different (the colors were faded away) but you can still see the POLICE MMC or whatever it said on there. Its also slightly lighter if you weight it next to a regular one.
05-P71-300k+ Chassis - Vortech V3 intercooled, Rebuilt Level 4 Transmission from Darrin, edge racing 2800 high stall torque convertor, Heinous Billet rear upper/lower control arms, Spice ujoints, new watts linkage, new rear shocks, new control arms(up/low), New Rack&Pinion, Reinhart(87), BOC(87), MPT(91), Mo'sSpeedShop(91) Tunes, JMOD - (1/2, 2/3 spring removed, all holes drilled) redone by BCA now with a 1/2 spring, New front lights(side/head), Staggered PICO widen 17inch tires 285/40/17, Steeda pulleys(no alt pulley, 1 size smaller gates belt)., New Rotors, calipers and pads. 4.10 gears (carbon), forced lube mod, balanced driveshaft, Moog front/rear sway bar control arms. Ford racing intake, AUX transmission cooler.
1 registered (BlackNFast), 83 Guests and 112 Spiders online.
Old_Guy_Stu 108
bluejay_32 101
Dmblanch 61
a_d_a_m 56
RF_Overlord 46
GM_Guy 42
Moby_Vic 33
Ponyguy 30
Tenevic_P71 30
Bellwestern80 28
