Page 2 of 5 < 1 2 3 4 5 >
#2829011 - 04/19/14 08:38 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
kurt Offline
Loc: OH
Get out the cut off wheel.
07 P71 (MHS stage II cams, UDP, Kooks long tubes, 3650 swap)
02 FX4 F150 5.4 (custom dents)
68 mustang coupe (in pieces)
66 F250 240 L6 218 whp (Restored and not stock)
83 mustang gt (return of the 4v)
#2829023 - 04/19/14 10:03 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Captain_Slow Offline
^^^This
Ezbok, I'm going with a cable clutch setup.
Spoke with Liberty's gears on thursday, they should be getting around to my transmission either next week or the week after. Pretty massive backlog, to say the least.
Also, there were some fairly worn suspension bits on the BMW, along with a bad tie rod that needs to be replaced badly, so I'm in the process of replacing a bunch of bushings in the rear suspension and basically replacing all of the front suspension components. I figured it made sense to have my daily driver in good shape before tearing the merc apart. With a bit of luck the suspension work should be done this week.
Member of the 4.6 Mafia
#2836170 - 05/18/14 11:47 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Update: Pedals are mostly installed. Just need to wire up the brake light switch and remove some stuff that's hanging by the pcm blocking the clutch pedal. Pics soon.
Also, finally pulled both rear wheels and adjusted the ebrake so that it actually engages smile
Aaaand spoke to liberty last week. They're supposedly getting it torn down this week. Definitely taking their time on getting around to it.
#2836216 - 05/19/14 09:55 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
That seems to be a trend around here, once a project is started and a part is handed off to "professionals" for some work, it gets tucked away in a corner and they will get to it "next week".
#2836240 - 05/19/14 11:50 AM Re: All the cool kids are doing it.... [Re: BlackVic_P71]
This ^^^^^^^^^^^
dont give up man you are almost there.
comming back this fall
#2837201 - 05/23/14 10:30 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
So, a few things (pictures will follow soonish).
I actually managed to get the factory brake pedal switch to install with these pedals, albiet rotated somewhat differently than stock. I know this wasn't supposed to be possible on older versions of pier's pedals, not sure if I got lucky or a design change there.
There are a few things I noticed though. One end of the clutch quadrant that doesn't have any spacers/etc on it seems to have a bit of side to side play in it, is this normal or am I missing a piece that should go in there?
Also, as far as the hole for the firewall adjuster goes, I'm a bit nervous. From what I've read it seems that the way to go about doing it is take a pen/whatever and rest it on the top/part of the quadrant where the cable hooks and see where it hits the firewall, and start the hole there, correct?
From that point, drill the hole out larger and then use a dremel to expand it out to the size of the firewall adjuster, and then make a plate/spacer/thingy to hold it at the proper angle relative to the quadrant. Somewhere in here I'll probably want to take the brake booster out of the way for clearance.
Am I missing anything/any feedback on this step would be appreciated.
#2837284 - 05/23/14 06:11 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
I cant remember what version you have but i'm really curious to see that
The play side to side will give you some room for adjustment with the cable.Once you are perfectly set and the right tension is on the cable it wount moove but you can always use washers if you really want to be exactly st the way you want but I never did.
you pretty much got it
fell free to pm me if yuo need more info.
#2837826 - 05/26/14 11:34 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
I'll work on getting a shot of the brake pedal switch, but that seems to be working.
The good news: I finally heard back from liberty, got a quote and whatnot, trans already torn apart, it should be rebuilt early next week and ready to go.
The bad news: Broken studs on front wheel spacers again, no damage to the rim though. This is the second time I've had it happen, on the same wheel actually, over the last two years. I think, however, I've got a decent long-term solution in the works.
Lastly but certainly not least, Rizzo was kind enough to spend a bit of his day off sweating/burning his hands under my car to remove this:
The dreaded 3rd starter bolt is now removed, and based on the horror stories I've heard about getting it out, I'm quite glad for the help. It should make pulling the started way easier when I go to drop the trans. Also, thanks to rizzo, I found out some of my wheel studs were f-ed up, way better way of finding that out than having a wheel come off.
Edited by Captain_Slow (05/26/14 11:40 PM)
#2837850 - 05/27/14 06:17 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
that infamous third bolt nono
gald you are a few step closer smile
#2840492 - 06/07/14 12:49 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Update time.
Wednesday I spent getting the car moved to it's temporary new home where I'm working on it.
Prior to that on wednesday, I installed these, although the rears need to be tucked in a bit more:
Also on wednesday, I picked up the transmission from liberty:
I'm thinking rather than use a silver/aluminum colored paint, i'll probably just hit it up with a high temp clearcoat. I'm glad I asked them to glassbead the case, it looks awesome.
The trans already had a 26 spline input shaft. In addition to that liberty did the following: replaced 2nd gear, which had some chipped teeth, brand new 1-2 and 3-4 synchro assemblies, new blocker rings for all synchros, new bearings, bronze shift fork pads, billet shift keys, and they shot peened and polished some of the internals for smoother shifting. Can't wait to see how it drives.
Today, I finished moving my tools and the rest of the parts I have out to the garage I'm working out of, got my to-do list taped up on the wall, and drained the trans fluid. The fluid was surprisingly clean given the trans has ~180k on it, and the fluid has 45k or so. Also drained out the torque converter and started removing the wiper cowl.
More coming tomorrow.
#2840521 - 06/07/14 09:29 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
nice smile
#2840546 - 06/07/14 11:51 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Loc: Ventura County, CA.
So Shiny!
#2840558 - 06/07/14 02:27 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
STLVIC Offline
Loc: Minnesota
What kind of wheels are those? They look awesome!
2004 MGM - Ice Blue - Tastefully Modded
Former Panther: 2006 Interceptor - POTM - March 2013 - Mods:
Drivetrain: 2nd CAT delete, Summit Racing mufflers, ported/polished plenum and TB, Transmission J-Mod and upgraded internals, Summit Racing underdrives, Ford Racing 3.73s, BOC 87 Octane Tune, 170 degree T-Stat, Brake Motive drilled and slotted rotors, PowerStop ceramic pads.
Best ET: 15.05 @ 91.15 MPH, not bad for bolt-on's grin
Exterior: Tinted windows, Mustang GT Premium wheels - black w/ aluminum caps and Nitto NT450's (255 front, 275 rear), Lowered 1.25" all four corners, S55 black tail lights, blacked out headlights and corners, fog lights, Mach 1 chin spoiler.
Other Rides:
2008 F350 King Ranch CCLB DRW - 6.4L Diesel, Deleted, Tuned, Exhaust
1984 Olds Cutlass - 468 Big Block Olds
1984 Ford Bronco II - trail and camping rig!
#2840567 - 06/07/14 04:03 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Thanks guys. The wheels are Esm-002r's. Similar design to our hpp rims.
Question for people with sw catbacks... Is it normal to need to disconnect the exhaust to remove the driveshaft?
#2840986 - 06/09/14 02:03 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
PoliceInterceptr Offline
I had a Hurst short shifter on my 6 speed in my '94 Trans Am. I really liked it. Also had a Stage III clutch. Came with both of these though, so I really couldn't compare them to stock. But I realy did like the feel fo that set up.
2012 F150 - 5.0L Coyote, 4x4 w/elocker, on 35"s
2003 Mustang GT - Lowered on 18" Dodge Magnums. *SOLD*
2000 Crown Vic P71 (few mods) - *SOLD AFTER 8 YEARS*
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." - George Orwell.
"America is all about speed - hot, nasty badass speed." - Eleanor Roosevelt.
5 registered (hansking12, Moby_Vic, a_d_a_m, Bellwestern80, 1 invisible), 68 Guests and 114 Spiders online.
bluejay_32 116
Moby_Vic 89
JeffBoudah 77
Old_Guy_Stu 73
Armada Master 53
a_d_a_m 47
DudeAbides 47
Dmblanch 46
Ponyguy 42
SocalSam 36
