Page 3 of 5 < 1 2 3 4 5 >
#2841205 - 06/10/14 11:33 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Captain_Slow Offline
Got this done last night...
Next up is stripping the interior and cutting holes for the shifter and firewall adjuster
Member of the 4.6 Mafia
#2841346 - 06/10/14 08:51 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
a classic picture
comming back this fall
#2841398 - 06/10/14 11:25 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Isn't it?
Got the car back on the ground today, stripped the seats and interior bits out. Next up is cutting the hole in the floor and firewall!!
Also had a decent talk with my buddy about how we're going to go about fabbing up the revised crossmember mount, should be interesting.
#2841443 - 06/11/14 07:57 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Rainyp71 Offline
Loc: North Carolina, USA
Add that to the flipped off autos collection :p
2000 P71 Crown Vic former Gordonsville, VA Police Wrecked @ 200,199 Miles - All fixed! Currently 250,000 Miles
GMAX As-05 tires, 3.55 gears, Ford 28 spline limited slip w/ carbon clutches, upgraded trans cooler, custom trunk false floor, autometer tach, Sony Double DIN Head Unit, KYBs all around.
#2842348 - 06/14/14 10:52 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Well, I'm pretty sure I've hit the point of no return now. Did this last night smile
Today I should be doing the hole for the firewall adjuster.
Also took the starter in for a rebuild earlier in the week, and ordered some parts I still needed (speedo recalibrator, control for the reverse lockout solenoid, wiring pigtails)
#2842463 - 06/14/14 11:01 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
mmmmm, floor vents. laugh
Nice progress!
#2842617 - 06/15/14 09:38 PM Re: All the cool kids are doing it.... [Re: BigMerc96]
Nice progress!
Thanks man!
#2842620 - 06/15/14 09:43 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
So, while I missed STAP this weekend frown I did get some good progress made.
After drilling the pilot hole for the firewall adjuster I went out and picked up this:
Which I used to drill this:
The stepped drill bit was perfect for the firewall hole, just a tad bigger than the steeda adjuster in diameter, and makes cutting a hole in the sheet metal (with an uneven surface) really easy. Also, the hole seems to be pretty well lined up with the clutch quadrant, so that's definitely good news.
Also clearcoated the transmission, removed the flexplate, and replaced all of the O2 sensors.
#2842634 - 06/15/14 10:36 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
that is excelent work smile
#2842967 - 06/17/14 01:43 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
I've also been meaning to post this up for awhile. It needs some cleanup, but it's the step-by step todo list I've been working off of as I've gone through the swap. I figure it'll probably be helpful for others as well. Eventually I'll post the whole thing in proper format, or as a wiki even. Also, there's a method to the color coding
#2845185 - 06/26/14 11:37 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Update:
Wiring done, other than VSS/Speedcal stuff.
Firewall adapter is coming along, need to play a bit with the angle and weld it up.
Flywheel and clutch are both installed.
Transmission is back under the car, with ToB and clutch fork installed. Should be getting bolted in tomorrow.
#2845223 - 06/27/14 05:47 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
nice so it's only a matter of weeks now before it's back on the road ?
#2845228 - 06/27/14 07:04 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
I'm hoping 2 weeks on the high end
#2845361 - 06/27/14 08:30 PM Re: All the cool kids are doing it.... [Re: Captain_Slow]
Thats sound whats left to do smile
#2845775 - 06/30/14 12:42 AM Re: All the cool kids are doing it.... [Re: Captain_Slow]
So, transmission is partially bolted in, flush against the block. It was a [censored] getting it on over the dowels on the block, definitely a tight fit.
Firewall adjuster plate is tack welded on, and with the cable run out, the angle looks pretty good, clutch seems to be engaging, although there's a bit more slack in it than I'd like, so I ordered a double hook quadrant.
Big items left: finish up the plate for the FWA
- modify the rear crossmember
- order new driveshaft
- put everything else back
Pier: How/where do you usually route the clutch cable? Right now I've got it going down, under the zip tube, looping between the lower control arm and the frame, and into the trans. It's got plenty of room, away from the exhaust, but I'm a tad worried about running it along the control arm.
5 registered (RF_Overlord, DudeAbides, a_d_a_m, RipWixomAssembly, Davidzq), 56 Guests and 91 Spiders online.
bluejay_32 116
Moby_Vic 89
JeffBoudah 76
Old_Guy_Stu 73
Armada Master 53
Dmblanch 46
a_d_a_m 45
DudeAbides 44
Ponyguy 42
SocalSam 36
