#4111976 - 06/08/21 04:25 PM Powermaster 8-57140: opinions please
sgc2c Offline
Loc: Boca Raton Florida
Is the Powermaster 8-57140 a drop-in replacement for my stock alternator?
I have a 1990 Grand Marquis LS with the stock weak alternator.
This Powermaster is allegedly 140 Amps. Looks like a good upgrade.
Is it a 3g?
I’d like to try it if it’s a straight-up simple replacement.
Opinions, pros and cons please …
Thank you.
#4111992 - 06/08/21 05:41 PM Re: Powermaster 8-57140: opinions please [Re: sgc2c]
Bellwestern80 Offline
CVN Discord: Edsel
Loc: Evans, Georgia
That Powermaster is a 2G styled alternator, but it's configured to work in a one-wire setup, so no need for the factory harness.
However, I'd recommend the use of a proper 3G or 6G alternator. A 3G uses the factory voltage regulator connector, you just need the single wire connector to the stator to splice on to it.
The 6G needs a completely new connector, but only uses two wires instead of the three like the 3G.
Both need a new charge cable run to the starter solenoid as the factory charge cable is not sufficient enough to carry the increased load. The use of a 175 amp Mega fuse in an inline holder is recommended.
My Cars:
-1964 Mercury Comet 202 (116K Miles | 170 I6) - Awaiting Repairs in a Cozy Garage
-1997 Mercury Grand Marquis LS (225K Miles | nPI 4.6) - The Daily Workhorse & April 2013 POTM Winner
3 registered (GrumpMarky, BlackNFast, 1 invisible), 44 Guests and 303 Spiders online.
bluejay_32 111
Old_Guy_Stu 85
Ponyguy 62
a_d_a_m 58
Moby_Vic 56
Dmblanch 46
DudeAbides 41
JeffBoudah 36
Lance01 35
Davidzq 33
