Page 98 of 98 < 1 2 96 97 98
#4112308 - 06/12/21 06:08 PM Re: 5.4 Swap FAQ's [Re: 03LTC]
dixiebandit69 Offline
5.4 Club
Loc: Texas
Originally Posted By 03LTC
Have you ever gotten any timeslips or dyno'd the car?
No, in fact I'm still running the baseline "safety tune" from Marty at Mo's Speedshop because I just CANNOT get the software to work with my computer. Very little help, as well.
Originally Posted By 2004_p71
Speaking of the trick flow heads here , I am 100% positive that I would have never made the power I am making without those heads .
I'm 100% positive of that, too.
#4112330 - 06/13/21 08:44 AM Re: 5.4 Swap FAQ's [Re: dixiebandit69]
what do you mean ?
#4112484 - 06/14/21 09:43 PM Re: 5.4 Swap FAQ's [Re: 2004_p71]
5.4 Club
Loc: Texas
what do you mean ?
I cannot get the initial fuel trim data to transfer to my computer (or any computer, for that matter. I tried three different ones.).
I installed the SCT software on all of them, and it never worked.
I've tried again over the years, and what usually happens is that the hand-held unit "updates" for about an hour, then shuts down.
I'm trying it again as I type, and for the last thirty minutes it's been saying that it's connecting to the WIFI...
And I'm still waiting. (This message sent over WIFI, for the record.)
At this point, I should have just paid to get it tuned locally; it would have been the same price, either way, and I would have gotten a dyno tune with some RWHP numbers.
The only reason I didn't is because the guy had a two-week back-log, and this is my daily driver.
#4112512 - 06/15/21 10:13 AM Re: 5.4 Swap FAQ's [Re: Bondfreak13]
sct are hot or miss sometimes . I had problems too trying to data log for marty . The same hapenned to the fuel trim .
#4113798 - 06/29/21 07:18 PM Re: 5.4 Swap FAQ's [Re: 2004_p71]
03LTC Offline
Ok so I bought the adapter plates but it turns out that they only have one set of holes drilled. They don't have the second set drilled and tapped for the 4.6 manifold. I contacted the eBay seller and they said it was a manufacturing error and to return it. Great. They also don't have any correctly manufactured ones in stock.
Any ideas what I can do now? Seems they're unavailable everywhere.
These are the ones I bought
https://www.ebay.com/itm/174605035068
Any members got adapter plates they wanna sell?
#4113866 - 07/01/21 11:59 AM Re: 5.4 Swap FAQ's [Re: Bondfreak13]
I am sure this is something you could end up doing yourself.
drilling and tapping is doable, just take your time . smile
#4114014 - 07/02/21 05:25 PM Re: 5.4 Swap FAQ's [Re: 2004_p71]
03LTC Offline
I tried mocking them up against the heads and intake and I don't think there's enough room to drill all the holes required, mostly around the crossover ports. Damn. There's gotta be something else out there
#4114024 - 07/02/21 08:17 PM Re: 5.4 Swap FAQ's [Re: 03LTC]
5.4 Club
Loc: Texas
1) Those adapters look like they're for NPI heads.
2) they list them at .5" thick, which would mean a pretty sharp transition to the intake port
You may have dodged a bullet.
For the record, I used the Professional Products spacers, and they are about 1" thick.
#4114070 - 07/03/21 07:38 AM Re: 5.4 Swap FAQ's [Re: dixiebandit69]
03LTC Offline
Yeah I wanted to buy the professional products adapter plates, but they've been discontinued.
Not sure what to do now about an intake.
I'm kind of considering abandoning the 5.4 swap and just putting the ported pi heads and stage 1 cams on my 4.6. I already have them, might as well use them
#4114086 - 07/03/21 12:01 PM Re: 5.4 Swap FAQ's [Re: dixiebandit69]
03LTC Offline
Just took a closer look and yes, they are NPI on one side and pi on the other. Yet they're listed as 4.6 to 5.4 adapters. Seriously.
Sigh
Edited by 03LTC (07/03/21 12:02 PM)
#4114164 - 07/04/21 08:29 AM Re: 5.4 Swap FAQ's [Re: Bondfreak13]
I wish Jordan at excessive motorsport (modular head shop ) would get is @ss running on the hardballrs intake production !
maybe it worth a shop to call him at that point and ask about ETA on the intake .
#4114178 - 07/04/21 01:34 PM Re: 5.4 Swap FAQ's [Re: 2004_p71]
03LTC Offline
+1 I'm going to call him tomorrow.
There's also a guy Shelby Mike that makes intake adapters and he shows a custom option...it's mostly 4v and coyote stuff, but if he will do a 2v adapter plate, that would be fantastic. It is $500usd for plates though. Eek.
#4114290 - 07/05/21 09:57 PM Re: 5.4 Swap FAQ's [Re: Bondfreak13]
I am about to start making 5.4 2V intake then laugh
#4114294 - 07/05/21 10:11 PM Re: 5.4 Swap FAQ's [Re: 2004_p71]
03LTC Offline
[quote=2004_p71]I am about to start making 5.4 2V intake then laugh [/quote,,,]
Turns out Shelby Mike doesn't make 2v stuff. facepalm
Its settled then. I just bought a mark 8 torque converter and my ported 5.4 heads are going on my existing 4.6,along with the trick flow stage 1 cams.
Not as much torque, but with headers, mzt and a tune I'm hoping for 300rwhp, but who knows.
#4114296 - 07/05/21 10:18 PM Re: 5.4 Swap FAQ's [Re: Bondfreak13]
You will still make great power , just not as much torque .
did you call Jordan at excessive motorsport ?
3 registered (KMBT, GM_Guy, RF_Overlord), 139 Guests and 15 Spiders online.
Traffic22 15
