#4112500 - 06/15/21 05:39 AM Need help: 2011 P7B stalls with AC on.
Pxcanon Offline
Loc: Arizona, USA
So I've been having a bit of a problem with my 2011 P7B, whenever I turn on the AC the car will stall whenever I'm at a stoplight or just idle, the car will turn on just fine however and it happens after let's say, an hour and a half of having the AC on, if I turn on the AC for let's say 10 minutes and then turn it off the car will still stall later in the day, but if I don't turn on the AC at all the car won't stall, at least that's what I thought since recently it has started to stall even if the AC is off, the car starts up just fine though as if nothing ever happened, I have engine codes for the EGR Valve that I already replaced twice but the codes are still there (I will make an edit with the codes when I get the chance), other than this issue this car runs like a beast but I would really like to get to the bottom of this issue. Thank you for any help and suggestions.
#4112506 - 06/15/21 09:53 AM Re: Need help: 2011 P7B stalls with AC on. [Re: Pxcanon]
AlleyG Offline
Loc: Raleigh, NC
A bad EGR on these cars causes some rough idling, though we didn't have stalling. If you still have the codes, you still have a bad EGR.
You replaced the EGR twice, as in $249 X 2? Yikes!
Al
2004 CVPI - 85k miles
1997 T-Bird LX - 85k miles
1994 Supra Turbo - 107k miles
Previous Fords:
#4112532 - 06/15/21 01:15 PM Re: Need help: 2011 P7B stalls with AC on. [Re: AlleyG]
Pxcanon Offline
Loc: Arizona, USA
Lol thankfully no, I was sent a replacement since the first one had an electrical fault.
3 registered (01boatman, Becker34, Bangster), 68 Guests and 110 Spiders online.
JeffBoudah 81
Armada Master 74
Old_Guy_Stu 72
Moby_Vic 65
Dmblanch 56
a_d_a_m 44
SocalSam 43
Ponyguy 42
