#4115502 - 07/17/21 10:08 PM Fuel pump deadhead pressure spec for a 2000 with 4
ReverseEngineerz Offline
Loc: United States
Hello,
This is my first post here.
I recently got a deal on a 2000 Crown Victoria with only 78,000 miles on it, but it has always had a hard start issue.
I immediately replaced the fuel filter, and a while later, the pressure regulator.
I've been reading through various posts here surrounding this issue and today I had the opportunity to take pressure readings.
I decided to look at the pressure right out of the pump, reading before it passes through the filter.
With KOEO, it jumps to 30 psi.
I believe I have a bad fuel pump based on that reading, but I don't know what it should be.
With a good fuel pump deadheaded into a gauge, should I expect 30 (I suspect not), or something higher (I expect so)?
Thank you in advance.
2000 Crown Victoria 79,000 miles (As of July 2021)
#4115682 - 07/19/21 10:59 PM Re: Fuel pump deadhead pressure spec for a 2000 with 4 [Re: ReverseEngineerz]
Loc: United States
I have continued to research this. Based on pump specifications, I believe the minimum should be 45 psi.
If anyone knows different, please let me know.
#4116644 - 07/29/21 08:56 PM Re: Fuel pump deadhead pressure spec for a 2000 with 4 [Re: ReverseEngineerz]
Loc: United States
I replaced the fuel pump.
I got the whole assembly with hanger,float, and sender.
The old one was a Ford pump, date code 2009.
I went with a Bosch from rockauto, and was disappointed to see "made in China".
But it now starts normally, I don't have to prime it with 6 cycles of key on- key off.
Oh and I stripped one of the bolt holes, different thread about that. Successfully solved by tapping it for a 1/4-20 (original was M6), and I torqued them all to 60 inch pounds, stopping short of the 89 inch pound spec that caused one of them to strip.
I'll keep an eye on it for leaks and revisit if necessary.
#4116668 - 07/30/21 12:11 AM Re: Fuel pump deadhead pressure spec for a 2000 with 4 [Re: ReverseEngineerz]
SocalSam Offline
Loc: SFV, Calif.
OEM is likely Chinese so don't sweat it.
3 registered (TheNarrator, Armada Master, RF_Overlord), 50 Guests and 86 Spiders online.
bluejay_32 117
Moby_Vic 82
JeffBoudah 76
Old_Guy_Stu 72
Armada Master 50
Dmblanch 45
a_d_a_m 44
DudeAbides 42
Ponyguy 42
SocalSam 34
