#4115670 - 07/19/21 09:48 PM 04 LX - Fuel Pressure Test
DKH Offline
Loc: WA
I just tested the fuel pressure on my 04 (150K) and I have a question.
Key "on" the pressure is at 40psi, bottom end of the normal range. Engine running the pressure drops to and stays at 30psi, 10psi below bottom end of normal range. The hold pressure is within spec.
The car is running slightly rough but not throwing any codes.
Is this definitely a replace the pump situation, or is there something else that I should be checking that could affect fuel pressure other than the pump?
Thanks!
#4115678 - 07/19/21 10:47 PM Re: 04 LX - Fuel Pressure Test [Re: DKH]
dixiebandit69 Offline
5.4 Club
Loc: Texas
With the engine running, pull the vacuum line off of the fuel pressure regulator.
It should pick up to 40 psi or so.
If not, probably new fuel pump time, or maybe time for a new fuel filter. Or a new fuel pump relay.
Maybe all three.
#4115688 - 07/20/21 12:19 AM Re: 04 LX - Fuel Pressure Test [Re: DKH]
KOER FP should be 40 lbs, not 30. I've not measured it KOEO. Only time I've ever seen mine read differently was when I drove to the supermarket and the car sat in the hot sun for a while. When I came out and started it, FP was 51 lbs and as I drove home (about 4 miles) the pressure slowly dropped back to 40. I assumed this was the fuel strategy to prevent vapour lock.
#4115802 - 07/20/21 06:27 PM Re: 04 LX - Fuel Pressure Test [Re: dixiebandit69]
DKH Offline
Loc: WA
Thanks for the suggestions.
With the engine running, I did pull the vacuum line off the fuel injector pressure sensor (mine does not have an actual fuel pressure regulator) and there was no change in fuel pressure. This has me wondering if the sensor is bad, but I'm not going to run out and replace it unless I'm sure, as it costs over $100.
The fuel filter was new when I did the check.
I'm hoping its the relay.
Thanks again.
#4115804 - 07/20/21 06:28 PM Re: 04 LX - Fuel Pressure Test [Re: RF_Overlord]
DKH Offline
Loc: WA
Good to know. Thanks.
4 registered (BenCook, NM117, cptn60, 1 invisible), 67 Guests and 96 Spiders online.
Old_Guy_Stu 108
bluejay_32 102
Dmblanch 67
a_d_a_m 59
GM_Guy 42
Moby_Vic 36
Ponyguy 30
Rootintootin 28
SocalSam 28
