#4115952 - 07/22/21 11:17 AM 1993 P71 erratic jumping speedometer
93p71 Offline
Loc: New England
1993 P71.
The analog 140mph speedometer needle periodically jumps around erratically. It does it sometimes while driving and it also does it while the key/ignition is turned to accessory mode with the engine off. There are also times when it works completely normal and reads accurate speed as should. Transmission and car seems to operate normal when it does it.
Wondering what the cause is and how to fix?
Speed sensor on transmission?
Bad speedometer gauge cluster?
Is is bad for the car/transmission to drive it like this?
#4115980 - 07/22/21 05:33 PM Re: 1993 P71 erratic jumping speedometer [Re: 93p71]
Bellwestern80 Online   content
CVN Discord: Edsel
Loc: Evans, Georgia
I’d check two things right off.
The first would be the body ground off the battery. There should be a heavy connection that goes down to the engine or frame, and a smaller connection that goes to the fender. If the small one isn’t hooked up, some electrical components like the instrument cluster may behave funny.
Second would be to inspect the VSS and wiring harness coming off the transmission. Ensure the wiring harness is not chafed and rubbing on any surfaces.
Since the speedometer is 100% electric, there should not be any risk to operating the car with it doing that, however it would be reasonable to determine why it’s doing that.
My Cars:
5 registered (WSTRLNG, bobb, SocalSam, derekghs, 1 invisible), 61 Guests and 105 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 49
a_d_a_m 47
SocalSam 43
Ponyguy 40
