#4115984 - 07/22/21 06:04 PM 03/04 TC Memory Seat Wiring
Fomocop71 Offline
Loc: Texas
Hope you guys can shed some knowledge on this.
I have searched on here to little info on the wiring for these seats.
I have a 03 Towncar Cartier. I’m installing 06 Towncar seats. I wired the passenger side as it had the 6 way plus most panthers use. But on the driver side it does not have the standard 6 way plug. It’s has rectangular connector which goes to the DSM it has a square 13pin connector and the air bag connector.
Would you guys have the wiring diagram that I can wire the seats to work with the door switch or what I have to do to make it work on the driver side ?
2011 Ford Crown Vic P7B
#4115990 - 07/22/21 07:46 PM Re: 03/04 TC Memory Seat Wiring [Re: Fomocop71]
Davidzq Offline
Loc: Seattle, WA
The easiest method would be to simply swap the 06 covers/foam onto your 03 frames.
If swapping frames isn't an option...
Did your 03 have memory seats?
If yes, then you'll essentially need to pull the wiring/modules from your old seats, and install the in the new seats.
If no, the 06 seats should have the brown seat base connector still. Simply unplug the portion which routes to the DSM, and plug into your car's harness.
Then you'll need to cut and splice the recline, lumbar, airbag, seatbelt wires.
Or you might be able to simply swap harness.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4116000 - 07/22/21 08:03 PM Re: 03/04 TC Memory Seat Wiring [Re: Davidzq]
Fomocop71 Offline
Loc: Texas
You are correct. My 03 has MEMORY seats. So it has the 3 connectors 1 being the rectangle connector and a square connector.
The 06 seats do have the brown connector but my 03 does not have that connector.
Let me rephrase that. The 06 TC does have the brown connector but my 03 TC does not have the connector coming from the car itself.
I see that the 03 does have the brown connector but it goes from the DSM to the seat motors.
Edited by Fomocop71 (07/22/21 08:08 PM)
0 registered (), 38 Guests and 75 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 48
a_d_a_m 47
SocalSam 43
Ponyguy 40
