#4116360 - 07/26/21 07:51 PM MM factory subwoofer came in..what’s next? Tips?
SDHOUHK07 Offline
Loc: San Diego, CA
I just received my Mercury Marauder factory subwoofer enclosure along with factory amp attached to it with the wire connector. My car is what’s on the signature. How can I go about hooking it up?
1998 Ford Crown Victoria LX HPP
-Medium Wedgewood blue metallic
-Dark denim blue leather interior
-LX HPP "BBS style" wheels
Mods so far:
-03-11 Defroster duct retrofit
-Sony XAV-AX1000
-2X JBL Club 8622F 6X8 in front doors
-Noico sound deadening material applied in both front doors
-USMEI Dual QC3.0 USB Charger Socket in place of OEM cigarette lighter
-Vleds 5K rear license plate bulb.
-Natika WD-011 Back up camera installed to the left of my California license plate
-Mercury Marauder factory subwoofer enclosure
-JBL Club 6X9 Rear deck speakers.
#4116398 - 07/27/21 06:06 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
GoldPanther Offline
BOK contributor
Loc: Chitcagoland!
I'm not sure if the subwoofer started on the 2003, when I retrofitted mine my car had the connector prewired behind the back seat so I just plugged it in and grounded it, I also had an after market radio which you will need because a standard radio won't work.
So look behind the back seat if it could be possible to have the wiring prerun.
03 mgm ultimate edition.
#4116472 - 07/28/21 12:10 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
Turns out I do have that lucky subwoofer plug and the “premium” audio harness prewire connections on my 98 Vic. However, I’ll need to order that Ford premium audio harness from Amazon
Mods so far:
-Sony XAV-AX1000
#4116664 - 07/29/21 11:03 PM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
Now i ran into an obstacle. How do i attached the factory in dash amp connector harness supplied by Metra part 70-5701 to my Sony radio harness?
Mods so far:
-Sony XAV-AX1000
#4116676 - 07/30/21 06:41 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
GoldPanther Offline
BOK contributor
Loc: Chitcagoland!
If your aftermarket radio has subwofer output try plug those RCA cables there, if not plug them in the rear RCA set. From my kit I plugged them in the rear RCA and I notice that when I change the balance to the left the subwoofer works and when I change the balance to the right the woofer don't work.
#4116794 - 07/31/21 03:36 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
I noticed some click pop noises going as I change different EQ settings on my head unit. Will I need this 12V to 5V "Stepdown" wire from AXXESS?
https://www.amazon.com/Axxess-Interface-...0K1X4&psc=1
Mods so far:
-Sony XAV-AX1000
#4116886 - 08/01/21 04:33 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
https://www.youtube.com/watch?v=T1DzhJ20e08
So i followed this guy advice did the wiring as instructed but my subwoofer speaker isn't working frown i test lighted the ground connection to the subwoofer speaker and it light up but the thicker connector, the power doesn't.
I connected that spliced in RCA cable into the "sub out" connection on the back of head unit could that be why its not working?
Edited by SDHOUHK07 (08/01/21 04:43 AM)
Mods so far:
-Sony XAV-AX1000
#4117152 - 08/04/21 03:00 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
Still no luck on my progress! What could be wrong?
Mods so far:
-Sony XAV-AX1000
#4117168 - 08/04/21 09:56 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
UnkleVic Offline
Loc: US Gulf Coast
We tested speakers with a flashlight battery. Should get a crackle when you touch the terminals.
2009 P71
1999 P73
#4118190 - 08/15/21 03:17 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
I put in a new tang band subwoofer speaker and still doesn't work! I'm really out of options!
Mods so far:
-Sony XAV-AX1000
#4118218 - 08/15/21 10:20 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
I have no idea what that is...
My 2003 factory wiring manual calls out the 6-pin connector on the subwoofer as follows:
Pin 1 - TX Signal
Pin 2 - RX signal
Pin 3 - Subwoofer mute
Pin 4 - Ground
Pin 5 - Not Unused
Pin 6 = Voltage supplied at all times
All of these circuits are fed directly from the subwoofer connector on the back of the head unit and the manual doesn't state whether the Mute function needs a ground or a voltage.
#4118254 - 08/15/21 05:22 PM Re: MM factory subwoofer came in..what’s next? Tips? [Re: RF_Overlord]
bluejay_32 Offline
Loc: wny
Pin 5 - Not Unused
Not Unused?
CVN POTM - February 2019 joy
#4118266 - 08/15/21 08:46 PM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
Gimme a break, man...you know I'm old and confused. gene
"Pin 5 - Not Used"
(Damn kids...)
#4118296 - 08/16/21 02:19 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: SDHOUHK07]
SDHOUHK07 Offline
Loc: San Diego, CA
I’ll take a picture of my wire tomorrow and post it. It’s for my 1998 Ford CV LX HPP. I’m going to be returning the MM factory subwoofer as I found anther MM factory subwoofer that finally have the bracket.
Mods so far:
-Sony XAV-AX1000
#4118298 - 08/16/21 02:22 AM Re: MM factory subwoofer came in..what’s next? Tips? [Re: RF_Overlord]
SDHOUHK07 Offline
Loc: San Diego, CA
Pin 1 - TX Signal
Pin 2 - RX signal
Pin 4 - Ground
Pin 5 - Not Unused
Good question. I’ll be taking a picture of my radio wiring and along with the subwoofer connector.
Mods so far:
-Sony XAV-AX1000
3 registered (negator, BlkPinkPanther, 1 invisible), 50 Guests and 103 Spiders online.
bluejay_32 101
Armada Master 86
JeffBoudah 80
Old_Guy_Stu 76
Dmblanch 59
Moby_Vic 55
a_d_a_m 47
SocalSam 45
DudeAbides 45
jmlock 42
