#4117032 - 08/02/21 12:57 PM Steering still stiff, whats next?
thephnx39 Offline
Loc: Texas
I replace the PS Pump and the steering is still as stiff as before. The fluid is topped off and I bled the system also, so what next should I do to find issue and get steering back to normal. Thanks for any advice
2006 MERCURY GRAND MARQUIS LS
#4117036 - 08/02/21 02:06 PM Re: Steering still stiff, whats next? [Re: thephnx39]
Check the intermediate and lower steering shaft u-joints. These are a common issue.
#4117046 - 08/02/21 03:44 PM Re: Steering still stiff, whats next? [Re: RF_Overlord]
thephnx39 Offline
Loc: Texas
How do I check them? Should I spray with PB Blaster and attempt to manually by hand turn them left/right?
#4117056 - 08/02/21 05:41 PM Re: Steering still stiff, whats next? [Re: thephnx39]
Yes.
#4117136 - 08/03/21 08:30 PM Re: Steering still stiff, whats next? [Re: thephnx39]
Lance01 Offline
Loc: Pa
I just bought another panther. A 04 Mercury Grand Marquis. The steering was so stiff you could hardly turn the steering wheel. I sprayed some PB blaster on the steering shafts and now the steering is back to normal.
Its only a temporary fix. My rusted steering shafts got to go. I will be ordering new Motorcraft steering shafts (upper and lower) from Tasca. All together you're looking at about 200$.
The bearing in the steering shaft which is also another item you could remove and replace easily when the steering shafts are out has unfortunately been discontinued. You can look on ebay. Seen a few OEM bearings on ebay.
#4117274 - 08/05/21 10:49 AM Re: Steering still stiff, whats next? [Re: thephnx39]
thephnx39 Offline
Loc: Texas
My steering is still stiff, when I turn the steering wheel there is a whine noise coming from the steering mechanism thats behind the brake pedal inside car, any ideas what to do?
I sprayed steering shaft under hood with pb blaster and the fluid is topped off.
#4117328 - 08/05/21 09:33 PM Re: Steering still stiff, whats next? [Re: thephnx39]
Lance01 Offline
Loc: Pa
Can you post pictures of the shaft?
#4118030 - 08/12/21 03:45 PM Re: Steering still stiff, whats next? [Re: thephnx39]
SocalSam Offline
Loc: SFV, Calif.
One last thing to check are the front roll bar end links which are attached to the hubs.
#4121356 - Yesterday at 07:38 AM Re: Steering still stiff, whats next? [Re: thephnx39]
Hound Offline
Did you ever resolve this?
I have a mechanic do most of the work on my 04 TC. I just do the tinkering like air box and tune, switches, minor stuff.
When I got it that he thought the rack and pinion unit was not in great shape but to drive it until it was giving me grief. It took almost two years but my steering shafts were rusted and the unit was sluggish. I just had him use a motorcraft reman unit, new shaft and heck, while it was all apart, I told him to put a new pump on it for luck. What's another Franklin while he's at it?
Drives like a dream again.
Edited by Hound (Yesterday at 07:39 AM)
2004 Town Car Ultimate in Autumn Red. Marauder box and MAF, Marty tune, 3.73 31 splines with Trac Lok.
3 registered (DudeAbides, MurkyMerc, Rootintootin), 77 Guests and 106 Spiders online.
Moby_Vic 76
JeffBoudah 74
Old_Guy_Stu 69
Armada Master 54
DudeAbides 51
a_d_a_m 49
Dmblanch 46
Ponyguy 43
SocalSam 38
