#4117154 - 08/04/21 03:43 AM P71 Rear Defrost
STR Offline
Loc: TX
Been trying to figure out my rear defrost. I found out after I ripped off the C pillar trim that the driver's side has been hit and repaired. Badly. The bodywork looks perfect on the outside, but the window frame itself is a mess (it looks like they hooked onto the C pillar to pull the body straight, and the trunk floor has ripples on that side.. nothing on Carfax of course).
Does power come in to the defrost grid on the passenger or driver's side on a 2007? The wire coming off of the driver's side (black or grey with yellow stripe) is cut a few inches into the plastic panel. Throwing a meter on the passenger side terminal and using the door latch (on the pillar) as a ground, with the defrost turned on, gives 0 volts, so if power comes in from that tab, there's no power. I've already checked fuses and swapped relays around with known good ones; the light in the switch does come on, and I hear a click somewhere in the dash when I try to turn it on.
The accident damage appears to be to the LR door and C pillar; reaching into the quarter panel from the trunk, everything feels smooth. Whoever did the body work (aside from paint) did a great job at hiding everything. :/
I did look several pages back, for what it's worth. I'll probably see if my library has a Mitchell book for the car soon; this is the only real issue I still have with it. The AC causes the back window to frost up on really humid days (look I'm a bit hot blooded okay, don't judge me for running it on max AC when it's only 90 outside!), it'd be nice to have the defrost working.
The pic makes it look like there may be a fusible link in the cut wire, but it's not doing much good if it's cut.
e: radio reception, with both the factory AM/FM radio, and my aftermarket Pioneer head unit, are good, so the antenna portion is working to some degree.
Edited by STR (08/04/21 03:50 AM)
#4117172 - 08/04/21 10:59 AM Re: P71 Rear Defrost [Re: STR]
Both. You need to place your meter leads on both the left and right tabs. My 2003 factory wiring manual doesn't specify which tab is which polarity.
If there's no voltage, then you need to check the power in to the antenna/defroster module which is behind the passenger side C pillar or, depending on year, may be on the package shelf between the speakers.
#4117192 - 08/04/21 03:15 PM Re: P71 Rear Defrost [Re: STR]
Davidzq Offline
Loc: Seattle, WA
Power is applied to the passenger side tab.
The driver side is ground, and the wire should be screwed into the C pillar where the patchwork is. But you may ground it by any means you prefer.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4117196 - 08/04/21 03:40 PM Re: P71 Rear Defrost [Re: STR]
Thanks for the clarification, David. bow
#4117624 - 08/09/21 08:42 AM Re: P71 Rear Defrost [Re: RF_Overlord]
STR Offline
Loc: TX
Thank you David! I'll find a suitable ground, then troubleshoot further. I'd already tried swapping relays and checking fuses before I found that.... mess.
The protective rubber cap was still on the connection on the glass, so nobody even bothered trying to hook it up after the window was replaced. I found that lead sticking out from behind the trim, tried hooking it up, then removed the trim and found that it was cut...
I haven't checked the antenna module yet, but is it safe to assume it's getting power if I have no issue with radio stations? Everything comes in clear, both with the factory radio and the aftermarket Pioneer I have in there (which does digital HD radio - every local station that broadcasts in digital comes in as digital, no flip-flopping back and forth between digital and analog). There's a connector going from the C pillar to what looks like the antenna, but I haven't removed the trim on the passenger side.
I was checking between the passenger side tab and a known good ground, with key on/engine off and the defroster switch turned on (light in it was lit up, anyway). There's also nothing between the speakers on the package shelf, so I'm going to assume it's behind the pillar cover on the 07.
#4117642 - 08/09/21 09:43 AM Re: P71 Rear Defrost [Re: STR]
I don't remember the year the location switch was made, but I do believe you're correct.
#4117672 - 08/09/21 03:08 PM Re: P71 Rear Defrost [Re: STR]
Tenevic_P71 Offline
Loc: US
Antenna module is behind passenger C pillar cover on 06+. Or perhaps they moved it in 05 with the addition of mast antenna.
I'm having problem with no radio reception in my 06. Need to check for power at that module.
One of the defrost power tabs was broken off the glass so I'm assuming that hasn't worked for a while either.
#4117690 - 08/09/21 05:43 PM Re: P71 Rear Defrost [Re: STR]
Davidzq Offline
Loc: Seattle, WA
The antenna filter module is located in the passenger C pillar, as is the Remote Keyless Entry/TPMS antenna.
If the light on the switch is on, the grid/module has power (unless the wire is broken/cut)
David Hensley
2 registered (FordNewbie, lance54r), 56 Guests and 84 Spiders online.
bluejay_32 101
Armada Master 86
JeffBoudah 80
Old_Guy_Stu 76
Dmblanch 59
Moby_Vic 56
a_d_a_m 47
DudeAbides 45
SocalSam 43
jmlock 42
