Page 2 of 2 < 1 2
#4116810 - 07/31/21 10:27 AM Re: No more Marauder or PI airboxes? [Re: Warped9]
Big_Pimpin Offline
Loc: NC
I got a police tube and air box from LKQ pretty reasonable. Lots of them still out there. I have not installed them yet. Waiting for other mods so I only have to tune it once.
#4116824 - 07/31/21 11:34 AM Re: No more Marauder or PI airboxes? [Re: Big_Pimpin]
Warped9 Offline
Loc: Brockville, Ontario, Canada
This is where I’m at. I want to upgrade gears and add a Trak-Lok at the same time as swapping in the new air intake so I’ll need to tune it only once.
This pandemic derailed my upgrade plans because some of the stuff I want needs to be ordered from the States, but with the border closed I can’t get across to Ogdensberg NY to pick up my stuff at the UPS store (to save some coin on shipping).
I’ve decided on pretty much everything I want to do with one exception. I’m undecided on whether or not I will eventually get the Stainless Works headers to go with my SW exhaust.
Edited by Warped9 (07/31/21 11:47 AM)
2004 CrownVic LX in Spruce Green Metallic
#4116910 - 08/01/21 10:47 AM Re: No more Marauder or PI airboxes? [Re: Warped9]
Big_Pimpin Offline
Loc: NC
I have the long tubes but am trying to decide if I do them only or port the heads and maybe cams.
#4117150 - 08/04/21 12:36 AM Re: No more Marauder or PI airboxes? [Re: speedfreak]
ClayBelt Offline
Loc: Leon County
Originally Posted By speedfreak
Originally Posted By ChoreMe
Went the K&N route lol
Those K&N filters are garbage, they just have a great marketing campaign. They don't filter well. Guy's who ran them on diesels doing oil analysis saw worryingly large increases in damaging contaminates with them. The oil from the filter contaminates you're MAF sensor making your engine run poorly. And then it's not sealed to the radiator support like the factory box so instead of getting cool air, you're sucking the hot under hood air, costing more power. With the factory box sealed there's also a slight ram-air effect because of the high pressure area behind the headlights when you're driving. That factory Marauder setup, with a basic paper filter, will flow more than enough clean air to support 500hp.
K&N's are good for what they were designed for, race cars that get the engines inspected and torn down regularly.
Some of those disadvantages can be outweighed with some heat reflective tape, sheet aluminum, and rivets but I will agree the filters are pretty [censored].
#4117422 - 08/06/21 04:28 PM Re: No more Marauder or PI airboxes? [Re: Warped9]
ChoreMe Offline
Loc: Louisiana
Not sure how This became a "bash the k&n" post but he asked what I did and showed him. Also was able to get 300 whp NA by adding the intake. Will also work in my favor with the head light out and while spraying nitrous and having cobra cams.
#4117424 - 08/06/21 04:30 PM Re: No more Marauder or PI airboxes? [Re: Warped9]
ChoreMe Offline
Loc: Louisiana
But any way, I have a Marauder box and mass air and tube for sale when you are ready.
#4117908 - 08/11/21 12:19 PM Re: No more Marauder or PI airboxes? [Re: Warped9]
Danger2manifold Offline
Loc: Little Poland, CT
I mean if you have a bending brake, or a metal working hammer and a sturdy piece of square tubing, you could bend up some sort of heat shield for the cone filter. It may also be possible to modify the stock airbox to act as a heat shield, though I've never tried it
Current Panther:
Past Rides:
#4118160 - 08/14/21 02:00 PM Re: No more Marauder or PI airboxes? [Re: Warped9]
Agent2006 Offline
Loc: PA
Air intakes on mostly stock 2V engines are a total waste $$$ you guys....K&N oil will mess up your MAF
#4118616 - 08/18/21 08:53 PM Re: No more Marauder or PI airboxes? [Re: Warped9]
Hound Offline
Do the aftermarket CIAs have 80mm MAF to go with them? There's another P71 advantage.
2004 Town Car Ultimate in Autumn Red. Marauder box and MAF, Marty tune, 3.73 31 splines with Trac Lok.
#4119292 - 08/25/21 01:24 PM Re: No more Marauder or PI airboxes? [Re: Warped9]
Anthonysvic Offline
Loc: Florida
I have an 08 with the K&N panel filter. When I first opened it from the plastic it came in, I blew off the excess oil from the filter and installed it. I have since cleaned it twice with their cleaner and haven't exactly re-oiled the filter before reinstalling it into my cvpi airbox without any issue's. She's a totally stock ripper.
2008 P71 125k miles, cut coils up front, moogs out back on kyb's. Heinous rear bars, custom watts by me, adtr front & rear sways. Magnaflow glasspacks with stock tailpipes. Transmission currently on the bench at Mikes, Jupiter Transmissions doin all the upgrades. 3.73's on schedule, and perhaps a 5.4 dohc swap. Have a Painless headlight harness to be installed but picked up the HF 20" fog/spot light, mounted in the middle of the pushbar, that totally works great. for now...
#4119312 - 08/25/21 06:51 PM Re: No more Marauder or PI airboxes? [Re: Anthonysvic]
speedfreak Online   content
Loc: Massachusetts,USA
Running a dry K&N is about the worst thing you can do short of an open intake, the filter media openings are huge in comparison to a dry filter. The oil film is what catches all the fine particulate. Without oil you're letting in all the fine abrasives through that are gonna do the most damage once they reach the oiling system. How many miles have you driven like this? It'd be interesting to see what an oil analysis says,
Marty tuned 2006 LX Sport: enlarged Air Box intake tube to 4" and sealed to radiator support, stock "Sport" front spring/ arnott HD rear air bags, KYB PI spec gas-a-justs all around, 28.5mm front sway bar, 21mm rear sway bar (both with poly bushing), 3:27 locker rear, Heinous rear control arms, Metco watts link, SW cat back w/ chambered mufflers, 20% tinted windows, drilled/slotted rotors, black AMR rims 19"x8.5 245/45/19 front, 19x10 285/40/19 rear, SVT badge on decklid, Sony head unit, kenwood 6x8s@ 45watts, jbl 12" sub @500W
Page 2 of 2 < 1 2
2 registered (Ethanb538, LTC_Dave), 129 Guests and 9 Spiders online.
Traffic22 15
