#4120662 - 09/12/21 02:29 PM 96 Vic MAF ground
Laid_Back Offline
1996 Crown Vic Base model 99K
I have a P0102 code. I cleaned the MAF with MAF spray. Did not help the situation. It sometimes hesitates from a dead stop. I had just replaced the IAC valve, which seemed to help, but it still hesitates a little and also occasionally runs bad at highway speed, seems to bog and lurch a little and then smooth out. Next I then did the multimeter test on my MAF before replacing it. When I did the test to check for ground coming from the PCM (tan wire), it does not read 12 volts. .82 is the best it will do. I unplugged the PCM and hooked it back up hoping it was just a bad connection. No change. Any ideas here? I did not go any farther testing the MAF since it apparently isn't getting adequate ground from the PCM.
Laid Back Country Picker
#4120754 - 09/13/21 01:52 PM Re: 96 Vic MAF ground [Re: Laid_Back]
hkerekes Offline
Loc: NC
I have a good 1996 maf for sale if you are interested.
I can post it in the for sale section.
Edited by hkerekes (09/13/21 04:13 PM)
#4120784 - 09/13/21 07:59 PM Re: 96 Vic MAF ground [Re: hkerekes]
Laid_Back Offline
Do you have a 96 PCM for sale? I think that is my issue.
#4120876 - 09/14/21 08:55 PM Re: 96 Vic MAF ground [Re: Laid_Back]
hkerekes Offline
Loc: NC
I dont, we are still using it and a Terminator X max isnt in the budget yet. Did you check for continuity between the ecu wire and the maf? Make sure the ecu/maf are disconnected and make sure the issue is the wiring or the computer. If i had to guess its in the wiring and you have a good computer.
#4121016 - 09/15/21 08:36 PM Re: 96 Vic MAF ground [Re: hkerekes]
Laid_Back Offline
I have not, but I need to do that before I start paying for a computer. Thanks sir.
2 registered (derekghs, ColescottFTW), 55 Guests and 91 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 50
a_d_a_m 47
SocalSam 44
Ponyguy 40
