#4121372 - 09/18/21 10:06 AM What’s Wrong? Maintenance Light and Engine Fan On
MisterMike Offline
Loc: The Peoples Republic of Massac...
This is a strange combination.......
After driving my ‘11 CVPI dor about 20-30 minutes the “wrench” light to the right of the transmission indicator on the instrument cluster comes on. When this happens the emgine cooling fan comes on. The CEL does not come on and there are no error codes in the controller. The temperature gauge reads normal.
Any idea what is going on?
Thanks in advance.
MrMike,
Marblehead MA.
"Mister Mike", Chief Engineer, Amateur Radio Station W1RC
Founder and Benevolent Dictator, New England Amateur Radio Festival, (aka NEAR-Fest),
At the Beautiful Deerfield NH Fairgrounds (Next one October 15th and 16th 2021)
All Crown Vics Welcome! Plenty of surplus Motorola radios and lightbars!
"Best #@! Hamfest on the Planet!"
"The Inmates are Running the Asylum!" da TimTron, WA1HLR.
#4121508 - 09/19/21 11:08 AM Re: What’s Wrong? Maintenance Light and Engine Fan On [Re: MisterMike]
Davidzq Online   happy
Loc: Seattle, WA
Wrench light indicates a non-emissions or manufacturer fault code is stored.
Cheap scanners cannot read these codes.
Plug in to a better scanner.
Also check the wiring to the cylinder head temp sensor, which is located underneath the intake manifold on driver side. The wiring runs to a connector on the front of the driver fuel rail. Damage or corrosion here would result in the fan coming on when sensor signal is lost.
The fan would also engage whenever AC is selected, or whenever engine reaches 210°.
Edited by Davidzq (09/19/21 11:10 AM)
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4121642 - 09/20/21 11:47 AM Re: What’s Wrong? Maintenance Light and Engine Fan On [Re: MisterMike]
MisterMike Offline
Thanks, David.
0 registered (), 51 Guests and 92 Spiders online.
bluejay_32 119
SocalSam 87
Ponyguy 62
Dmblanch 53
RF_Overlord 48
Moby_Vic 48
Davidzq 47
DudeAbides 44
Old_Guy_Stu 43
Armada Master 42
