#965360 - 06/17/06 12:10 PM horn keeps blowing fuse
mkfanatic Offline
Loc: Hamilton, OH
My horn keeps blowing my fuse, I've had this problem ever since the horn incident. For those of you who don't know about it (or don't remember, because I did post about it once) I had an incident with my horn. I came home one day from work, parked my car, went inside, and by the time I got inside the 3rd floor condo, I could hear a horn honking outside through my patio door. I thought maybe someone's car alarm was going off or something. I look outside, then open the door a little bit a go "is that my car?" So I go outside and yep, sure enough, it was my car, honking it's fool head off. So I try to figure out a way to stop it from honking. I was thinking too straigh or I WOULD have though to pull the fuse but it was just honking like crazy and after about 20 minutes it blew the fuse. When that happened, I never really tried fixing the horn. Now, after about a year and a half after that happened, I'm trying to get my horn working again. I already replaced my horn relay so it's not that. Someone told me a wire could be grounding out and causing it to blow the fuse but I checked and I can see no wire touching metal. If I put a fuse in and try using the horn with the car turned off, I can honk it quite a few times before it blows it. If I try honking it with the car turned on, it will only honk once and blow the fuse immediately. The fuse I am talking about is the one under the distribution box.
1993 Crown Victoria P74 (wrecked)
1995 Crown Victoria P72 (sold to junkyard)
Mods: P71 Computer
2003 Crown Victoria P74 Sport
Mods: MM MAF + Airbox and K&N Air Filter, 04 Zip Tube, 3.73 gears with trac-lok LSD, AMMC Driveshaft, Tailshaft w/ Forced Lube Mod, and 93 Tune from Lonnie @ BOC
#965361 - 06/20/06 09:41 AM Re: horn keeps blowing fuse
mkfanatic Offline
Loc: Hamilton, OH
no ideas?
Mods: P71 Computer
#965362 - 06/20/06 11:04 AM Re: horn keeps blowing fuse
themercman Offline
Loc: Macomb, Michigan
is your air bag light blinking and also does your cruise control work?
Riley,
1992 Mercury Grand Marquis AKA The Merc(totaled)11-28-98 to 12-2-06 R.I.P
1996 Dodge Ram 1500 4X4 360
#965363 - 06/20/06 11:19 AM Re: horn keeps blowing fuse
PKariher Offline
Loc: Durham, North Carolina
I would also look at the steering wheel. It sounds like the horn switch is stuck on.
Just to clarify, it is a constant horn not a beep, beep, beep?
2003 Crown Victoria LX
#965364 - 06/20/06 12:11 PM Re: horn keeps blowing fuse
observer Offline
are you 100% certain the horn is known good
1997 P71 145K miles
#965365 - 06/21/06 08:47 AM Re: horn keeps blowing fuse
mkfanatic Offline
Loc: Hamilton, OH
Honestly, I don't know if the horn is good or not. As I said, I can push my horn button and get a couple honks out of it before the fuse blows with the car turned off and I can only push it once to get it to honk with the car turned on before it blows a fuse. It doesn't honk by itself like it did that one day. Also, the air bag light is not blinking and no, my cruise control doesn't work either. It did when I first got the car but somewhere along the way it stopped working.
Edited by mkfanatic (06/21/06 08:48 AM)
Mods: P71 Computer
#965366 - 06/21/06 09:44 AM Re: horn keeps blowing fuse
themercman Offline
well that cound like a faulty clok spring to me
Riley,
#965367 - 06/21/06 11:59 AM Re: horn keeps blowing fuse
mkfanatic Offline
Loc: Hamilton, OH
The only thing I see at AutoZone.com is an airbag clockspring. I don't have an airbag in my steering column. I think my vehicle may have previously been in an auto accident before I bought it and the bag must have deployed but no one ever replaced it before I came along. What difference would this make? Can anyone explain?
Mods: P71 Computer
#965368 - 06/23/06 03:04 PM Re: horn keeps blowing fuse
mkfanatic Offline
Loc: Hamilton, OH
Can anyone confirm or deny this? Or could I just have a bad horn?
Mods: P71 Computer
#4124238 - 10/13/21 09:02 AM Re: horn keeps blowing fuse [Re: mkfanatic]
davewaugh Offline
15 years later.....
If the horns run long enough, the insulation in the coils will burn up causing the coil wraps to short together. This just happened to my '04 when the steering wheel switch got stuck. I'll probably just disconnect the wheel switch and install a dash button and new horns. It's starting to cool off in New England and it needs to pass inspection in December.
#4124270 - 10/13/21 07:02 PM Re: horn keeps blowing fuse [Re: mkfanatic]
Hound Offline
Well it's about time this guy got an answer from someone! 🤣
2004 Town Car Ultimate in Autumn Red. Marauder box and MAF, Marty tune, 3.73 31 splines with Trac Lok.
#4124276 - 10/13/21 08:15 PM Re: horn keeps blowing fuse [Re: Hound]
SocalSam Offline
Loc: SFV, Calif.
It's CVN.
1 registered (young831), 38 Guests and 73 Spiders online.
bluejay_32 130
Old_Guy_Stu 105
SocalSam 92
JeffBoudah 66
Dmblanch 63
Moby_Vic 62
a_d_a_m 62
Ponyguy 58
Hound 58
Armada Master 54
