#4124352 - 10/14/21 04:26 PM Supporting Mods for MHS Stage 2 Cams?
tc092 Offline
Loc: NY
I'm thinking of getting MHS Stage 2 Cams. I've already done a 3.55 rear axle swap; P71 intake, dual exhaust, and aluminum driveshaft; BBK 70mm throttle body; Trick Flow 75mm plenum; and a Marty tune. I expect I need the tune updated, so that's not a huge issue. Jmod is on the list to get at some point. Are there any other supporting mods I'd need (e.g., torque converter)?
2008 Mercury Grand Marquis GS. ~120K miles. 3.55 Trac-Lok rear, aluminum driveshaft, P71 airbox, BBK throttle body, Trick-Flow intake plenum, Marty tune, P71 dual exhaust, HAP rear springs, Cadillac 4-note horns, leather interior swap, aftermarket radio head unit w/ bluetooth adapter, aftermarket speakers and subwoofer, Continental cubby armrest, carpeted trunk organizer, smoked P71 taillights, bumper tuck, full-size spare.
Pending Mods: 18-spoke 17" wheels.
#4124376 - 10/14/21 08:03 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
dixiebandit69 Offline
5.4 Club
Loc: Texas
Upgrade your valvesprings, and change your valve seals while your at it.
#4124580 - 10/16/21 01:28 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
Big_Pimpin Offline
Loc: NC
Stall converter needed for stage 2 cams IIRC. Head porting would be very beneficial. If you were to port the heads then might as well get long tube headers at this point.
#4124696 - 10/17/21 02:23 AM Re: Supporting Mods for MHS Stage 2 Cams? [Re: dixiebandit69]
Colt604 Offline
Loc: Arizona, USA
The MHS Stage 2 Cams description says upgrading the springs isn't required if they are degreed properly. I do agree with you on upgrading them while you have the valve covers off to be on the safe side.
2004 Mercury Grand Marquis GS
-2.5" catback, stainless steel, dual exhaust with H-pipe - Flowmaster Super 10 mufflers.
-Ford Trac Lok differential, 3.73 gears, 31 spline axles, CVPI aluminum driveshaft.
-Marty tune.
#4124768 - 10/17/21 04:41 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
tc092 Offline
Loc: NY
I would have MHS degree the cams, so springs would be a nice-to-have but not a need-to-have at that point, right?
Any recommendations on a torque converter? I'd imagine I'd need something with a higher stall than the P71 converter, right?
I need to be able to pass a NY emissions inspection, so while long tubes would be nice, I'd imagine I'd have to pay a premium to have ones with cats, right?
Thanks for the feedback so far!
#4124780 - 10/17/21 06:35 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
ClayBelt Offline
Loc: Leon County
Depends on how much you think you'll be revving it out to. If you ride it out much past 5500 or so frequently I'd do the valve springs if only for the peace of mind. No point in adding to the odds of throwing a rocker and fecking up a perfectly good cam or valve cover
#4124788 - 10/17/21 09:37 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
5.4 Club
Loc: Texas
Don't be a dumbass, just replace your springs and seals while you have the chance.
The high performance game isn't cheap. But valve springs are not that expensive.
I think a CVPI converter will work for you nicely.
Just find a good new or reman unit, and you should be good.
I forgot to mention that you should do the J-Mod before you do anything else on these cars. Or any Ford with a 4R7OW.
I am not joking around, it's a night and day difference in the daily driving experience, and it increases the life of the transmission.
It's cheap, it's easy, it makes the car faster, SO DO IT.
Edited by dixiebandit69 (10/17/21 09:43 PM)
#4124946 - 10/19/21 06:29 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
tc092 Offline
Loc: NY
Any particular specs or recommendations for the valve springs? Any part number recommendations I should be on the lookout for with respect to the torque converter?
And on the subject of "while you have X out, also do Y" are there any other things that are worthwhile to be doing? For example, I'd imagine doing the rear main seal wouldn't be a bad idea while the trans is out for the TC, right?
#4124988 - 10/19/21 09:27 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
ClayBelt Offline
Loc: Leon County
I’ve got a set that someone sent me with my cams, haven’t opened the box so idk if they’re factory or not but if you want to shoot me a PM you can have them for a negligible amount and the ride if they’re not stock. Since you’re already going to have the top end open may not be a bad idea to have those heads ported or swap a set of ported heads on
#4125452 - 10/23/21 02:48 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
Big_Pimpin Offline
Loc: NC
When I was gung ho about major mods I didn't want to spend big bucks for a name brand converter on a 135k mile tranny and have it eventually go boom taking my $$$ converter with it so I ordered a reman converter for a Mercury Marauder. Supposed to have more stall than a 2v application. Yep, it is still sitting in the box on the floor.
#4125522 - 10/24/21 12:52 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
Colt604 Offline
Loc: Arizona, USA
MHS Stage 2 Valve Springs may be a good idea.
https://www.modularheadshop.com/i-24493869-mhs-600-lift-stage-2-pi-valve-springs.html
-Marty tune.
#4125590 - 10/24/21 11:05 PM Re: Supporting Mods for MHS Stage 2 Cams? [Re: tc092]
5.4 Club
Loc: Texas
Yes, change your rear seal while the transmission is out. I usually do.
I used Comp valvesprings with my XE268s.
Right now, RockAuto has some Melling valvesprings that have even better specs than Comp for a MUCH better price.
P/N 466554
0 registered (), 32 Guests and 60 Spiders online.
bluejay_32 130
Old_Guy_Stu 105
SocalSam 92
JeffBoudah 66
Dmblanch 63
Moby_Vic 62
a_d_a_m 62
Hound 58
Ponyguy 57
Armada Master 54
