#4125466 - 10/23/21 03:41 PM Ballistic Panels Install Notes
SocalSam Online   content
Loc: SFV, Calif.
I finally found a set of Ballistic Panels made by BLS Textiles and with a Ford engineering number. The internet says they were a $2,400 option. Mine for $32 plus my time and some cussing at the JY. After watching this video, the panels were getting installed.
Here are passenger side panels. If using PC, right click to view full size image.
Spec sheet.
There are no YT videos on installing the panels. I looked but did not find written instructions. I practically destroyed the donor door getting the panels out which was good practice for my vehicle. Here are my notes. I'm going to shortcut a lot of it because I'm assuming you know how to dis-assemble a door. Sorry, no pictures or video of the install.
1. Remove door panel.
2. Remove door mirror.
3. Remove inner and outer window weather strips. Outer strip is held by one nut. Pry upwards and pull back.
4. Remove DDM.
5. Remove bolts for window tracks, there is one on each side.
6. Remove window. You will need two 1 or 1 1/4 inch x 1/4 inch screws and nylon bolts to reinstall window.
7. Remove window regulator assembly. There are two nuts at top and two rivets at bottom. Two more bolts and nuts needed to reinstall. 1 x 1/4 is good.
8. Remove speaker.
9. Install threaded inserts on door intrusion bar flanges, there are two, Also install inserts on panels, two more.
7. Hang panels on sill. Wiggle them to align with threaded inserts. Rear, top, and bottom screws are easy enough. The front screw is a pain. I used blue painters tape to secure the nut to the socket. After a lot of cussing, I managed to seat the screw.
8. Install all door components. The hardest part is putting the window back as the panels eat up access space. Roll regulator down near the bottom to give more space. Reach from behind to insert screw. The screw on the right is tricky. Use close ended socket wrench and tape screw to wrench. With some patience and a lot of cussing, the screw will go in from the back. Leave wrench in place. Once screw threads are accessible, roll window to position where the electrical connector is. This gives straight shot to the screw. Tape nut to socket. I used a wad of tape in the socket to level the nut with the socket opening.
9. Outer weather strip may not fit over the panel hangers. Simply widen the opening by hand.
Keypad Add
#4125512 - 10/24/21 06:40 AM Re: Ballistic Panels Install Notes [Re: SocalSam]
Old_Guy_Stu Offline
Really impressive that those will stop an AK round. But the glass still won't. I imagine the intended use is to use the open door as a shield in tactical situations rather than as protection in daily driving.
#4125778 - 10/25/21 09:35 PM Re: Ballistic Panels Install Notes [Re: SocalSam]
Loc: SFV, Calif.
Installed passenger panels today. Once again, the hardest part was re-installing the window. This time, I taped the screw to the window. This was much easier.
Door disassembled.
Panels hang on outer sill.
Location of forward threaded insert on intrusion bar flange.
Rear threaded insert.
Keypad Add
#4126314 - 10/28/21 08:32 PM Re: Ballistic Panels Install Notes [Re: SocalSam]
Hound Offline
That's an awesome find at a junk yard!
2004 Town Car Ultimate in Autumn Red. Marauder box and MAF, Marty tune, 3.73 31 splines with Trac Lok.
#4126622 - 10/31/21 07:17 PM Re: Ballistic Panels Install Notes [Re: Hound]
Loc: SFV, Calif.
Yup, JY find. Checkout person had no idea what they were.
Keypad Add
5 registered (wolf_walker, Kibbers, DES, Dmblanch, a_d_a_m), 59 Guests and 138 Spiders online.
SocalSam 67
bluejay_32 64
Old_Guy_Stu 54
2011CVPI 53
a_d_a_m 53
hot__box 50
Dmblanch 46
RF_Overlord 41
GrumpMarky 35
hkerekes 32
