#4125782 - 10/25/21 09:58 PM 2003 parts fitting what models/Catalytic delete?
ImpalassGuy Offline
Loc: Nj
2 questions
1. I have a 03 cvilian model. Will the alternator fit all years 98-2011? and im assuming most parts will fit from a 03 to any year on these vehciels 98-2011..
2. Also intersted in rear catalytic delete. Woudl this affect emissions?
thanks for the educated replies...
#4125784 - 10/25/21 10:09 PM Re: 2003 parts fitting what models/Catalytic delete? [Re: ImpalassGuy]
SocalSam Offline
Loc: SFV, Calif.
03 to 08 have the most parts commonality. 02 minus less so. 09 was a re-design year. A lot was carried over but there are differences.
Rear cat delete is not worth the effort. Stock motor will not be faster.
Option Adds: Message Center Instrument Cluster , Re-Key Locks , Passenger Door Lock , Autolamps , Ballistic Panels
#4125786 - 10/25/21 10:20 PM Re: 2003 parts fitting what models/Catalytic delete? [Re: ImpalassGuy]
Davidzq Online   happy
Loc: Seattle, WA
You have a 4G PCM regulated alternator. This was used on 03-04 civilian vic and MGM only.
05+ civilian and 03+ P71 used a 6G alternator. You can use the 6G alternator (including the p71 200A) by splicing on the 6G connector. The outer two wires gwt swapped.
Most other parts are 03+.
The transmission is 01-03 (02- have an extra sensor, VSS, ignore the extra connector).
Most of the electronics are more year specific.
03-05 for the LCM
For rear cat delete, you just need to weld in some 2" pipe.
As this is after the rear o2 sensors, emissions tests will not be affected unless your area does visual inspections.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4125874 - 10/26/21 01:35 PM Re: 2003 parts fitting what models/Catalytic delete? [Re: ImpalassGuy]
Short answer is yes, it will affect tailpipe emissions, but probably not enough to fail an inspection, if your state still does a tailpipe probe.
The bigger question is WHY you want to do this? There's absolutely no benefit.
#4125996 - 10/26/21 08:48 PM Re: 2003 parts fitting what models/Catalytic delete? [Re: ImpalassGuy]
ImpalassGuy Offline
Loc: Nj
ok thankyou folks....btw im not getting email notifications on replies.....very weird
0 registered (), 51 Guests and 92 Spiders online.
bluejay_32 119
SocalSam 87
Ponyguy 62
Dmblanch 53
RF_Overlord 48
Moby_Vic 48
Davidzq 47
DudeAbides 44
Old_Guy_Stu 43
Armada Master 42
