#3055626 - 02/09/16 02:39 PM J Mod on 2011 CVPI
j262byuu1 Offline
Loc: Saint Louis, MO
Just did the J mod today. Sorry no pics since I want to finish the J Mod asap in a snow day..
I used the J mod kit bought from 88grandmarq which included a Super Tuff pre-drilled separator plate, a Sonnax Overdrive Servo Regulator (http://www.sonnax.com/parts/2402-overdrive-servo-regulator), a Sonnax Boost Valve (http://www.sonnax.com/parts/2393-boost-valve-kit) and some other stuff (filter, gasket...). Also I bought 12 qt Mercon LV from ford dealer ($5.1*12=$61.2, cheaper than Amazon) and I used 10 qt.
I did not remove any of the springs (1-2 and 2-3). The result is awesome, the 1-2 and 2-3 shifts firm but not harsh. OD is firmer than before but not uncomfortable.
The most challenging thing was doing J mod in a snow day..My hands were almost frozen. However I'm happy with the result. By doing the J mod I know that my transmission (actually valve body) is in good condition.
Overall, very happy. Thanks 88grandmarq!
Edited by j262byuu1 (02/09/16 02:58 PM)
2011 CVPI, 120K, 1568 idle hours, NHP unit.
BH1976 Headlight relay upgrade, LCM Bypass, full LED conversion
If you lives near St.Louis I can turn off you dark car mode ...
#3056490 - 02/09/16 09:09 PM Re: J Mod on 2011 CVPI [Re: j262byuu1]
88grandmarq Offline
4R70W rebuilder
glad it worked out.
#3056810 - 02/09/16 11:53 PM Re: J Mod on 2011 CVPI [Re: j262byuu1]
09mnsp Offline
Loc: Minnesota, U.S.
Nice!
09 P71
#3057786 - 02/10/16 12:30 PM Re: J Mod on 2011 CVPI [Re: j262byuu1]
88grandmarq Offline
4R70W rebuilder
I was going to make a post about this, but since the vehicle owner beat me to it, i will expand on his post.
OP contacted me in December about a Jmod on his car. Originally we were going to meet in person and I do the work, but our schedules didnt allow for this. Instead, I shipped the parts for him to install. Parts included in the kit I shipped; pre-drilled Superior Tuff plate, new sonnax shift valves, new gaskets and filter. He requested the transmission shift firmly, so several of the holes were drilled larger than normal.
Hole 1 - .160
Hole 2 - .113"
Hole 3 - .180"
Hole 4&5 - .116"
Hole 6 - .161"
Hole 7 - .093"
hole 8 - Not used
hole 9&11 - .125"
hole 10 - .093"
Ford updated the pressure regulator valve in 2010, which eliminates the wear normally seen on older valve bodies. in this case the Sonnax replacement valve is not needed on 2010 or 2011 valve bodies
Since holes 4&5 and being drilled larger than .093" its is necessary to open the hole in the gasket to match the new larger hole. I use a hollow punch for this.
#3059138 - 02/11/16 09:55 AM Re: J Mod on 2011 CVPI [Re: j262byuu1]
88grandmarq Offline
4R70W rebuilder
here is the missing picture from my post earlier.
#3060578 - 02/11/16 11:50 PM Re: J Mod on 2011 CVPI [Re: 88grandmarq]
09mnsp Offline
What do you use to sand/deburr the plate after drilling it? That plate is so thick that it leaves more material to clean up than when drilling an oem plate.
09 P71
#3061177 - 02/12/16 09:56 AM Re: J Mod on 2011 CVPI [Re: 09mnsp]
88grandmarq Offline
4R70W rebuilder
i use an air powered sanding tool with a 2" disc. makes quick work of deburring the holes
#3062241 - 02/12/16 11:28 PM Re: J Mod on 2011 CVPI [Re: j262byuu1]
deezdrama Offline
Loc: central il
I thought I read that 05 and newer p71's pretty much had the jmod done stock. Or that the newer vics wouldnt benefit from the mod as much as the older vics.
Is this true?
I got the gaskets hanging in my garage from a few years ago but never did it on my 07.....
Im buying a 2010 p71 in the morning and wondering if the jmod would be worth the effort?
imgurl
<<<2007 Crown Vic P71>>>
175k
Precision Industries Stallion Torque Converter, New Ford Racing PI Intake, Polished plenum, Cat delete/duals/Thrush 2 chambers/3.5" tips, 18" Bullitt rims, 5% tint all around
<<<2010 White P71>>>
105k
15% tint, blacked door pillars, marauder corner lamps, HID projector headlights, 18" staggered Bullitts..... work in progress
#3064249 - 02/14/16 04:06 AM Re: J Mod on 2011 CVPI [Re: deezdrama]
88grandmarq Offline
4R70W rebuilder
Is this true?
completely un-true. all of these transmissions benefit from the Jmod. Some of the holes in the plate on the 2004 and up transmissions are already larger from the factory, but not all of them. all of these transmissions suffer from pressure loss in the valve body from worn pressure regulator valves and wear on the factory separator plate where the 2-3 accumulator presses against the plate. doing the Jmod, replacing he separator plate and replacing the shift valves eliminates the pressure leaks and makes the transmission shift better. 2005 and up transmissions have better EPC solenoid, so it already has more pressure. For a stock vehicle I typically drill hole 2 for the 1-2 shift smaller and drill hole 4&5 and 9&11 larger than what the Jmod spec calls for. From my experience, this creates a crisp, consistent shift with out being annoying
#4129168 - 12/01/21 10:09 AM Re: J Mod on 2011 CVPI [Re: j262byuu1]
tefkart Offline
Loc: west coast
I am leaning twards the complete body for ease of installation.
#4129320 - 12/03/21 02:03 AM Re: J Mod on 2011 CVPI [Re: j262byuu1]
2008interceptor Offline
Loc: Pennsylvania
I guess I can see why civilian models didn't get this and eventually did get part of it. Though for commercial use HD/P71 it would have made sense.
#4130096 - 12/11/21 09:12 PM Re: J Mod on 2011 CVPI [Re: 2008interceptor]
88grandmarq Offline
4R70W rebuilder
The transmissions are identical. so no clue what you are talking about.
#4130486 - 12/15/21 11:41 PM Re: J Mod on 2011 CVPI [Re: j262byuu1]
Jbawden Offline
Loc: Napa, CA
I've had 3 CVPI; two '04 and my current '08. I did the Jmod on both 04's, but then when I got the '08 I decided against it. I have zero complaints about the '08 shift characteristics, the factory tuning is about 95% how I would want it to shift.
Edited by Jbawden (12/15/21 11:41 PM)
2008 P71 SAP
#4131018 - 12/22/21 12:56 PM Re: J Mod on 2011 CVPI [Re: j262byuu1]
MIHAYLA Offline
Loc: UA
I did this modification for several vehicles from 1992 to 2005. Indeed, later cars are closer to Jerry's recommendations. And nothing more.
The most indicative in this case is objective control. I have measured the shift delay and shift time. Before and after modernization. We are talking about my Town Car 05. So, these indicators have almost halved.
In such cases, there is nothing to comment on.
MGM92
LTC05
#4131284 - 12/27/21 12:14 AM Re: J Mod on 2011 CVPI [Re: j262byuu1]
Traffic22 Offline
Loc: CA
Anyone reading and considering this should know Eric’s (88GrandMarq) work is very good. We shipped him our valve body, and he did the J-Mod. The reinstallation instructions he sends back with the valve body are excellent.
His customer service is second to none. We were looking for ways to cool our trans in race conditions, and I had several conversations with Eric. He provided excellent advice, and went above and beyond.
On top of all that, the J-Mod and valve body improvements are very much worth doing, even if your car is your daily driver and never sees racing or other severe duty. You’ll be happier with the shift characteristics and have piece of mind knowing the valve body is functioning more efficiently.
2011 P7B Former San Joaquin Co Dog Car. Current 24 Hours of Lemons Race Car. 132,000+ miles, 1500+ race track miles, 7500+ idle hours.
Fully gutted, roll cage, OMP Race Seat, 5 point harness, 3.73, Detroit Tru-Trac, Marty Tune, J-Mod by 88GrandMarq, CHE rear control arms and watts link, ARP watts link stud, Ridetech coilovers, ADTR sway bars, custom sway bar end links, Carbotech brake pads, 245/40/18 Falken RT615K+ tires on 18x8 Mustang wheels, Derale trans and PS Cooler.
May 2021 POTM.
3 registered (SocalSam, webestang, a_d_a_m), 40 Guests and 114 Spiders online.
SocalSam 67
bluejay_32 64
Old_Guy_Stu 54
2011CVPI 53
a_d_a_m 53
hot__box 50
Dmblanch 45
RF_Overlord 41
GrumpMarky 35
hkerekes 32
