Page 2 of 2 < 1 2
#4069668 - 07/04/20 07:44 PM Re: Fred's 1999 MGM [Re: Freddy12189]
What brake hoses did you buy? I don't think I've seen any braided lines made for a '98-'02. Its something I would like to do.
#4069670 - 07/04/20 07:51 PM Re: Fred's 1999 MGM [Re: BigMerc96]
Freddy12189 Offline
Loc: NY
Someone on the other thread said these ones so I got them. "Edelbrock 657302 -3 AN Straight Brake Hose to 10mm (3/8") Banjo - 13". I hope they are going to fit.
#4069676 - 07/04/20 08:10 PM Re: Fred's 1999 MGM [Re: Freddy12189]
If its a M10x1.0 bubble flare fitting for the line connection, it should work. Length seems about right from what I recall. The banjo on these cars is 3/8 or 10mm, so that side seems right. I've been thinking about ordering a set of '04 Mustang GT hoses because those are really close in length and have the correct metric ends, I think they will work since like that universal hose they have the "universal" type banjo fitting that can be rotated whichever way they need too. Then all you need is to make/modify a mounting bracket to attach them to the frame.
#4071430 - 07/21/20 08:27 PM Re: Fred's 1999 MGM [Re: Freddy12189]
Freddy12189 Offline
Loc: NY
The brake hoses were put off due to a mixture of the unbearable heat and a leaky gas tank.
I started smelling gas last week and saw the bottom was wet with gas. Not leaving any puddles yet but certainly rusted through the seam.
Today brand new gas tank, straps and sender/fuel pump. Now I have a working fuel gauge !
#4072034 - 07/26/20 10:16 PM Re: Fred's 1999 MGM [Re: Freddy12189]
tybalt92 Offline
Loc: Santa Clara, CA, USA
Good to know that you have a new gas tank. Your build setup is impressive.
#4084738 - 11/17/20 07:47 PM Re: Fred's 1999 MGM [Re: 124neta]
CrystalPistol Offline
Loc: Shenandoah Valley
Originally Posted By 124neta
I've always thought of the 98-02's like the ugly middle child of the best aero(95-97) and the best whale(03-05).
... Odd how that is, almost unfathomable even. I have always favored the '98-'02s Them '03 and newer just look like Ford just threw a different grille in the CV, even the Aeros look better head on.
Edited by CrystalPistol (11/17/20 07:48 PM)
#4084740 - 11/17/20 07:52 PM Re: Fred's 1999 MGM [Re: Freddy12189]
I've always liked the '98-02s, mostly because they retain the cool looking Aero corner lamp shape. Wish they'd have found a way to retain that for the '03+ cars (and yes, I HAVE Photoshopped my Marauder with those just for S/Gs).
#4084810 - 11/17/20 10:54 PM Re: Fred's 1999 MGM [Re: 124neta]
124neta Offline
don't get riled, sugar!
Loc: Il
I wish they would have kept a more aero style tailight pocket as well. Both to further distinguish models, and I just really dislike the 98+ look.
One day I will modify a taillight the same height as the fascia, then extend the quarter and shape it to the missing piece of taillight.
I will admit the way the corner lamps cut upward into the fenders and the skinnier shape of the headlights is attractive.
I could say the good things about HPP spokes they put on 98-02 models.
Unfortunately, 95-97 Aeros do it better.
Edited by 124neta (11/17/20 11:10 PM)
#4084840 - 11/18/20 07:48 AM Re: Fred's 1999 MGM [Re: 124neta]
The CVN version of "blondes have more fun"?
#4124684 - 10/16/21 09:33 PM Re: Fred's 1999 MGM [Re: Freddy12189]
Freddy12189 Offline
Loc: NY
I have to update with new pics soon. Got dual exhaust on it and rhino lines the roof because it was peeling badly and starting to rust. I put the liner because I put my boat on there and needed something thats tough. Worked well.
#4129328 - 12/03/21 02:58 AM Re: Fred's 1999 MGM [Re: Freddy12189]
GooneyBird Offline
Loc: The Netherlands
Originally Posted By Freddy12189
Gotta figure out what to do about a radio because it has none and someone cut all the wires so no plug anymore.
There are pinouts a'plenty online, and really, they're not too difficult to figure out. You get a ground, 12V Constant, 12V Switched, Illumination, possibly aerial remote (Did MGMs come with power antennae?), and 4x + and - for the speakers.
I had.... a rat's nest behind my radio in my CVPI, and soldered on ISO plugs. Really, the most difficult part of that all was running an extension chord for my soldering iron to the parking lot. I don't know how common ISO plugs are in the USA, but over here pretty much every aftermarket radio comes with a set of ISO > Radio adapter leads.
Just work methodically, occasionally check what you're doing with a multimeter (when it comes to the power leads that is), and for help I made a little conversion sheet from Ford > ISO. You can have that if you want to, but I'm not sure MGMs follow the same colors in the radio harness as a CVPI.
- 2007 CVPI. Probably the only one in a very, very large radius
#4129376 - 12/03/21 05:49 PM Re: Fred's 1999 MGM [Re: Freddy12189]
Dmblanch Offline
Loc: Utah
Speaking of the bother of running your extension soldering iron to the car, or the equal frustration of running a butane powered iron which then is too hot to put down at rest in the car between solders, I solved the problem with this:
Ryobi's 18v battery powered soldering iron.
Battery life is longer than you think, a place to safely put the tip, automatic cool down and shut off if you aren't using it. I love it.
1) 2002 White P71 - 89K miles. 2) 2003 B&W P71 - 74K. 3) & 6) & 11) 2005 White P71 - 54K, 74k, 115K. 4) 2011 Black P7B - 79K. 5) 2008 White P71 - 95k. 7) 2004 Silver P71 - 104K. 8) 2004 DT Red LX Sport - 111K. 9) & 10) 2010 White P7B SAP - 104K & 106K. 12) 2006 White P71 - scrapped. 13) 2007 Gray LX Sport - 125k. 14) 2006 White MGM LS Premium - 93k.
Page 2 of 2 < 1 2
0 registered (), 17 Guests and 79 Spiders online.
bluejay_32 70
SocalSam 68
Old_Guy_Stu 58
a_d_a_m 58
hot__box 56
2011CVPI 53
RF_Overlord 48
GrumpMarky 37
hkerekes 33
Dmblanch 31
