#4129370 - 12/03/21 05:31 PM 18x11 wide rims fit on the back of an aero
hkerekes Offline
Loc: NC
Has frame clearance and fits under the fender.
Yes my garage is a mess, i havent been home to organize it.
Edited by hkerekes (12/03/21 05:31 PM)
#4129396 - 12/03/21 08:13 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
dixiebandit69 Offline
5.4 Club
Loc: Texas
Yeah, but will the TIRES fit? What size were you thinking of running?
#4129406 - 12/04/21 08:31 AM Re: 18x11 wide rims fit on the back of an aero [Re: dixiebandit69]
hkerekes Offline
Loc: NC
295/40/18
They stretch on the rim a little so they fit just fine. I may have to cut the fender a little bit and add some flares due to the desired ride height, but getting the rims to fit was the first step.
The fronts are not going to be so easy. I may end up having to custom order rims at $575 each. I believe i need a -20 to -30 offset to clear the frame/swaybar. I really really hope i can avoid that considering i should have 4 rims.
#4129414 - 12/04/21 09:41 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
Old_Guy_Stu Offline
Check clearance with one side of the suspension jacked up. Looks like it might could rub with some body roll.
#4129466 - 12/04/21 08:20 PM Re: 18x11 wide rims fit on the back of an aero [Re: Old_Guy_Stu]
hkerekes Offline
Loc: NC
Im taking a sawzall to the fenders. I already know its going to need it since we already [censored] up a front tire. I may get some cheap fender flares, or just leave it. Having a car you really dont care what it looks like is awesome.
#4129476 - 12/05/21 05:59 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
Old_Guy_Stu Offline
I was thinking more of the rear wheelhouse, on the inner side. I guess you can wait and see where the tire hits and clearance it with a sledge.
#4129562 - 12/05/21 11:18 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
hkerekes Offline
Loc: NC
It looked to have plenty of clearance there but if not i can make some. Worse case i have to do a ghetto tub job, but it wont be a problem since looks are irrelevant.
#4129600 - 12/06/21 11:04 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
18x11 with what backspacing?
#4129614 - 12/06/21 01:52 PM Re: 18x11 wide rims fit on the back of an aero [Re: GM_Guy]
hkerekes Offline
Loc: NC
18x11 +8 offset
no spacer at all.
#4129714 - 12/07/21 06:52 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
BlackNFast Offline
I run 295/40/r18 nitto on 18/9.5 rims with 2 inch spacer.
Rubs pretty bad on bumps,haven’t rolled the fenders yet because I haven’t trusted anyone to do so,but soon hopefully. Around 7.125 on backspacing I believe.
Edited by BlackNFast (12/07/21 06:55 PM)
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 @ 14 pounds Max boost. T56 swapping next few months.
458 Rwhp and 441 FPT
Currently own:
1979 f250 Camper Special w/460 4 Barrel stock
2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4129724 - 12/07/21 08:59 PM Re: 18x11 wide rims fit on the back of an aero [Re: BlackNFast]
hkerekes Offline
Loc: NC
We almost ruined a 285/35/18 tire due to rubbing on the front fender. The good old sawzall is going to remedy that problem.
The 18x11 does fit upfront but i didnt get to check the clearance at full lock. With a 15mm spacer and 8 offset rim it clears the upper balljoint and my wilwoods.
#4129754 - 12/08/21 07:37 AM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
BlackNFast Offline
What are u doing with the car,looks like fun project to me.
Currently own:
#4129794 - 12/08/21 04:18 PM Re: 18x11 wide rims fit on the back of an aero [Re: hkerekes]
hkerekes Offline
Loc: NC
Endurance road racing. We run with Luckydog, Lemons, and will eventually end up running a Champcar or AER race but it will be less competitive there.
Its fairly fast now, have two second place and one third place trophy in Luckydog last year. We have the ability to win the Lemons Road Atlanta race this weekend. Whether we will or not is another story.
Moderator:  RF_Overlord
3 registered (SocalSam, DES, webestang), 70 Guests and 136 Spiders online.
SocalSam 67
bluejay_32 64
Old_Guy_Stu 54
2011CVPI 53
a_d_a_m 53
hot__box 49
Dmblanch 44
RF_Overlord 41
GrumpMarky 35
hkerekes 32
