#4132598 - 01/11/22 05:16 AM HVAC Air Flow Issue
White Falcon LS Online   content
Loc: SoCal
If I turn on the HVAC to any position where it's suppose to vent from the dashboard towards the cabin (VENT, NORM A/C or MAX A/C - manual controls), it vents in defrost mode to the windshield instead. After some time goes by, and the engine is at idle with high vacuum (e.g. at a stop sign), it'll switch to the dashboard air vents on its own.
If this was a constant vacuum leak, I reckon it would continually be stuck in defrost mode, but this one has me scratching my head. Pretty sure it's a vacuum issue, considering my auto parking brake release also stopped working. Thanks!
#4132616 - 01/11/22 09:59 AM Re: HVAC Air Flow Issue [Re: White Falcon LS]
Old_Guy_Stu Offline
Definitely a vacuum issue. Maybe the vacuum accumulator or the line going to it? There's only 2 miles of vacuum lines in these cars, so have at it!
#4132666 - 01/11/22 03:52 PM Re: HVAC Air Flow Issue [Re: White Falcon LS]
Davidzq Offline
Loc: Seattle, WA
Do you have manual or electronic controls?
The EATC unit uses o-rings which eventually crack and leak. I would suspect the one for the panel door has cracked. #007 is the size of the o-rings.
It's also possible the panel door hinge has broken, leaving the door stuck.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
#4132790 - 01/12/22 08:49 PM Re: HVAC Air Flow Issue [Re: White Falcon LS]
Dmblanch Online   content
Loc: Utah
Given the frequency of o-ring failure, that'd be my first bet, fortunately its cheap and easy to replace them all. Everybody who buys them has extras left over.
#4133368 - 01/19/22 08:33 PM Re: HVAC Air Flow Issue [Re: White Falcon LS]
1990LTD Offline
Loc: Nova Scotia
Definitely O rings.
What's the likely issue if the airflow is always at least slightly coming from the vents? It'll still switch between the other modes but it's always blowing a bit from the vents, it's easy enough to close them but I'm losing plenty of airflow and heat that way.
2007 Ford Escape - 3.0 Duratec / CD4E / 2WD - Rear converter delete, dual exhaust.
2008 Mercury Grand Marquis Ultimate Edition - 4.6 / 4R75E / 2.73 - rear coil conversion - DD
