Page 2 of 2 < 1 2
#4132794 - 01/12/22 09:31 PM Re: OK for rear axle to move in and out? [Re: ironmarinebill64]
BubbaGumpCo Offline
Loc: Nevada
Thanks for the reply. I guess I was just wanting a second opinion if I should pull the diff cover. I'll run it through the car was with the undercarriage wash and then see what's in there this next set of days off.
Would I have to pull the c-clips or can I see the ends of them while turning the tires? I did the axle a while ago and don't remember exactly. I do remember it being a [censored] to get it all assembled correctly because something moved and it only aligns one way.
#4132806 - 01/13/22 06:17 AM Re: OK for rear axle to move in and out? [Re: xcopkar]
ironmarinebill64 Offline
Loc: New York, USA
With the diff cover off and the Trak-Loc housing with its open side to you as you're looking at it, you should be able to see how much play you have (with the tire and brake rotor removed, laying on your back, you'll be able to stretch your leg and work an axle shaft back and forth).
Also, if you just remove the cross pin, you'll be able to up close inspect it to see if there's any wear on the pin. If there's none or slight, then the axle shaft ends wouldn't be harmed in any way - there'd be no contact to cause it.
When I installed the Richmond Gear axles in my Town Car, they were actually just a tad too long and had to touch the ends with a grinder to be able to install the cross pin and C-clips. But I still have about 3/32 - 1/8 of end play. Never been an issue.
Page 2 of 2 < 1 2
0 registered (), 17 Guests and 79 Spiders online.
bluejay_32 70
SocalSam 68
Old_Guy_Stu 58
a_d_a_m 58
hot__box 56
2011CVPI 53
RF_Overlord 48
GrumpMarky 37
hkerekes 33
Dmblanch 31
