#4133374 - 01/19/22 09:50 PM Ok abs delete?
01boatman Offline
Loc: Iowa
01 crown vic I understand that abs is a good thing, this car never sees snow, or super heavy rain, I've tried 3 abs modules and my dumb*ss tossed the original one, from what I understand 02 and below have a proportioning valve so could I use something like a 99-04 sve abs delete block? I've driven the car about a year with the module unplugged with the brake light on, and it stops fine never has locked them up or anything scary lol just the pedals slightly squishy, pled brakes multiple times new pads, rotors, calipers, rubber lines, master("bench" bleed) if anyone has any thoughts on why it wouldn't work, the car is a 4 wheel abs traclock car so it has 6 break lines, the delete plate in question does as well
2001 cv, c&L upper, 75mm tb, 3.55 rar, stewart wp, aluminum ds, console swap, sw longtubes, sw cat back, adtr 98-02 sc kit, now 6r80 swap, 100k miles(wrecked she done!)
1994 ltc, mint, all stock, 100k miles
Others: 05 marquis, 02 mustang v6:)
#4133430 - 01/20/22 05:52 PM Re: Ok abs delete? [Re: 01boatman]
Since I own more cars without abs than with, I'm okay with abs delete.
No idea about any of these delete blocks, best to ask those who make it.
#4133432 - 01/20/22 05:59 PM Re: Ok abs delete? [Re: 01boatman]
SocalSam Offline
banned
Loc: SFV, Calif.
Are you deleting because you can't fix it or because you think you can threshold brake faster and better than ABS?
2004 CV LX Sport #2
#4133448 - 01/20/22 07:44 PM Re: Ok abs delete? [Re: SocalSam]
01boatman Offline
Loc: Iowa
Oh I know the computer is much better than me, I would like to delete it because the module when bad, abs no com then hit bump and in comes bad, then went completely bad, put 2 module in it (used) 1 went bad in 2 day, the other didn't work, there also like hella expensive new, where should I by one if I was going to?,
#4133468 - 01/21/22 08:45 AM Re: Ok abs delete? [Re: 01boatman]
01boatman Offline
Loc: Iowa
I actually put some thought into it and I ordered a rebuilt module from autoecu, God I hope it works
Thanks Sam, your comment sparked my brain to not be slow lol
#4133470 - 01/21/22 09:48 AM Re: Ok abs delete? [Re: 01boatman]
SocalSam Offline
banned
Loc: SFV, Calif.
Members have lots of experience trouble shooting ABS. If you have replaced the module that many times, it is likely something else. Suggest you pull ABS codes. If your code reader is not capable, have Autozone pull the codes. Perhaps intermittent problem with a speed sensor in one of the hubs?
2004 CV LX Sport #2
#4133472 - 01/21/22 10:24 AM Re: Ok abs delete? [Re: SocalSam]
01boatman Offline
Loc: Iowa
I've pulled codes multiple times, with a snap on triton, if the lights on its no com, if it's off, it worked perfectly, the trac button would turn on and off, the 2 modules I put in both used, one was bad I believe and tho other my abs light went out but why Trac button didnt do anything, the sensors are good, I have replaced one. The connector has no corrosion
Edited by 01boatman (01/21/22 10:25 AM)
#4133474 - 01/21/22 10:34 AM Re: Ok abs delete? [Re: 01boatman]
SocalSam Offline
banned
Loc: SFV, Calif.
Yeah, seems like a mystery problem. It has to be setting a code. Communication problem is a U code. The fact that it sometimes clears with module swap indicates something in the connector is not right. Maybe loose pin or chaffed wire. Clean contacts on the ABS valve block with contact cleaner. Not sure if BOO switch is part of ABS but sticky switch will cause mystery brake problems so worth checking or changing.
2004 CV LX Sport #2
#4133490 - 01/21/22 01:23 PM Re: Ok abs delete? [Re: SocalSam]
01boatman Offline
Loc: Iowa
Sorry I ment the original ABS module the light would go in and out, never had a code through the scan tool would just say can not communicate, when the light was off it scanned fine no codes, then I swaped in the believed bad one, then the one that never through a light, but the trac button didn't function
#4133492 - 01/21/22 01:26 PM Re: Ok abs delete? [Re: 01boatman]
01boatman Offline
Loc: Iowa
Also I believ the harness is fine, I've followed most of it, the brake petal switch has never done anything strange, like brake light stay on or no shift into gear, thanks for all the idea tho I didn't think about the boo until you said it
#4133494 - 01/21/22 01:36 PM Re: Ok abs delete? [Re: 01boatman]
mkpctv Offline
Loc: South FL
I also wondered if ABS could be disabled but i'd rather not disable a safety feature, plus after seeing input from other members, its more complicated on later model panthers when that stuff became more computer controlled.
Just make sure to get the correct module, the modules with Trac Control (metal/plastic) will have 10 valves and the ones without (all plastic) will have 8 valves
I scored a used one off ebay and installed it and lights went away, but i kept my original and may send it out for rebuild to keep as a spare
2008 Mercury Grand Marquis GS - purchased Feb 2017 33k original miles
In the past:
2006 Chevrolet Cobalt
1998 Pontiac Grand Prix GTP
1988/1983 Chevrolet Caprice
#4133496 - 01/21/22 01:43 PM Re: Ok abs delete? [Re: mkpctv]
01boatman Offline
Loc: Iowa
Ya I ordered a metal/plastic 01-04 abs module with traction control, I've been running it unplugged with the connector sealed up with electrical tape, my dumb*ss though the original one away
#4133498 - 01/21/22 02:48 PM Re: Ok abs delete? [Re: 01boatman]
Modern ABS braking systems are designed to be fail-safe. If the ABS goes non-functional, you still have normal (non-ABS) braking capabilty.
#4133736 - 01/24/22 12:44 AM Re: Ok abs delete? [Re: 01boatman]
Tenevic_P71 Offline
Loc: US
Simply pulling the fuse has been a satisfactory "ABS Delete" on panthers.
However I wouldn't really recommend it especially on 05+ because it throws off the proportioning somewhat.
#4133790 - 01/24/22 03:24 PM Re: Ok abs delete? [Re: Tenevic_P71]
mkpctv Offline
Loc: South FL
Yeah that's the other reason I didn't bother trying any disable "hacks" on my 08
In the past:
0 registered (), 136 Guests and 14 Spiders online.
