#438767 - 05/05/04 09:42 PM AXLE--Mustang Posi on CV's
hagemenp Offline
I have heard that a rebuilt mustang gt posi can be put on a crown victoria. Is this true and how simple is it? Can it be put in directly or are more parts needed? Do these usually last very long, and will it damage the car in the long run? I want to use it to race others and go to the drag strip.
(I have a 98 crown victoria police interceptor, if that has anything to do with it.)
Edited by Liquid (06/13/05 11:41 AM)
If you can't run with the big dogs, stay on the porch
#438768 - 05/05/04 09:56 PM Re: Mustang Posi on CV's
BeefyBeefo Offline
Do a search about trac-loc and rear-ends.
Signature removed. See rules.
#438769 - 05/05/04 10:19 PM Re: Mustang Posi on CV's
2008interceptor Offline
Loc: Pennsylvania
Yes you can use it You will need a diff install kit which summit carries or even the shop that does it for you may have. I have a rebuilt posi from a f-150 which also has a stronger (s) spring in it as well as an extra set of clutches as well as I also went to 3.55 gears for a bit more acceleration from my 3.08's. Do take a search though as many people have upgraded their diffs from open their to a rebulit mustang, explorer crown vic f-150 28 spline 8.8" posi diff. If you are considering changing rear end gears do it at the same time. There are several different kind of diffs though for all season and daily driving use as well as "racing" a ford lsd is great. Take a look as here and if you do a seach on the web the different types of differentail units are discussed as far as their pros and cons for how they are being used.
#438770 - 05/05/04 10:20 PM Re: Mustang Posi on CV's
PatFromJersey Offline
Sir Laugh Alot
Loc: Glen Burnie, MD
Yes, the "Mustang" posi will work on your Crown Vic. Read this link from Charlie (Metroplex), and if you think you can do it yourself, go for it.
http://www.redpulsar.us/~coldfusion/TT.html
1932 Ford 5 Window Coupe Project 521/C6
2008 Ford Crown Victoria LX
#438771 - 05/05/04 10:50 PM Re: Mustang Posi on CV's
88grandmarq Offline
4R70W rebuilder
ALL Ford passenger cars use the same traction lock carrier. 28 spline axles and a 3/4" pinion shaft.
they are fairly simple to rebuild. Rebuild kit is avaiable from Ford for around $40, part # F5AZ-4947-BA. I also recommend the Ford synthetic 75w-140 gear lube, its great stuff.
You will need to shim the carrier to obtain the correct backlash when the carrier is installed, this requires a dial indicator. This can be challenging if you have never done it before.
#438772 - 05/05/04 10:55 PM Re: Mustang Posi on CV's
Loc: Pennsylvania
Actually some stangs (not gt's), cobras use a 31 spline as well as some hd trucks/vans/suv's. As well as there are 9" rear ends as well espicalyl on e-bay. While those aren't all normally daily driver passenger cars they can be and you could accidently get a 31 if you didn't bother to notice the difference.
#438773 - 05/06/04 01:38 AM Re: Mustang Posi on CV's
Kinger87 Offline
Loc: Gladstone MI
yes you have to be careful. some are 31 spline, but as you look you will find most to be 28 spline, which is most common, and what the crown vic has.
2003 Grand marquis all stock
#438774 - 05/06/04 01:45 AM Re: Mustang Posi on CV's
Loc: Pennsylvania
The lsd is the way to go as you can get them for a good price as quite a few fords off and on road have and are always upgrading and you can get a new or new-rebuilt lsd for alot less than new sometimes even with gears like 3.55's or 3.73's.
#438775 - 05/06/04 09:59 AM Re: Mustang Posi on CV's
88grandmarq Offline
4R70W rebuilder
No, they don't
The 2003 Cobra *might* use a 31 spline carrier, but thats it, everything else is 28 spline.
Only the 8.8 diff in the F/E-150 uses 31 spline axles with a 7/8" pinion shaft.
#438776 - 05/06/04 10:59 AM Re: Mustang Posi on CV's
AndrasOtto Offline
Loc: Waldorf, MD
Yeah, the '95 Cobra carrier I have is a 28 spliner
99 CV Deep Wedgewood Blue
12.947 @ 104.05
00GT PI 4.6l engine; 24# injectors; 190 lph intank pump; Marauder MAF; 75mm BBK t/b; Trick Flow Upper intake; SCT ProRacer Flasher; Performance Automatic AODE valvebody; Underdrive pulleys; 3.73 FRPP gears and Mustang Trak-lock; Level Ten 3000rpm converter; Ford shorty headers cut and welded to fit; 2.5" cat-back with X, high flow cats; NOS 05-171 4.6L Dry kit; 245/55/16 Toyo Proxes T1-S on 16" '95 CobraR replica rims.
#438777 - 05/06/04 10:23 PM Re: Mustang Posi on CV's
Loc: Pennsylvania
Oh the 2003 cobra isn't a cobra mustang? You can go to a 31 spline and there are several on e-bay right now 31 spline.
FORD 8.8 POSIUNIT 31 SPLINE 5.0 COBRA SVO SVT MUSTANG (Item number: 2476733349 )
heres another THIS IS A FACTORY FORD 8.8 31 SPLINE OPEN CARRIER IT DOES HAVE THE ABS RING ON IT BUT ITS (NOT PICTUERED)BUT CAN BE REMOVED IF NOT NEEDED THIS CAN GO IN ANY 8.8 FORD REAR WITH 31 SPLINE AXELS WITH OR WITH OUT ABS IT IS READY TO INSTALL.THIS IS A PERFECT FOR YOUR FULL SIZE BRONCO F-150 E-150 RANGER PICKUP.THIS WILL WORK IN ANY 8.8 REAR WITH 31 SPLINE AXELS(2476735199), another
This is a very good Ford 8.8 track lock 31 spline limited slip carrier. We are a 4x4 shop, and it was removed in favor of a locker. The milage was barely over 45,000, and it came from a 1998 Explorer.(2476630569 ), another
Used Ford 8.8 FACTORY 31 spline posi traction unit. Weighs 19lbs. This unit is in excellent condition. Ford P/N 2R3Z4026AA. Removed from a 2001Explorer with less than 14000 miles(2477389636), {{{{below is a link to the seach}}}}
http://search.ebay.com/ford-31-spline_W0QQfromZR7QQhtZ1QQsaregionZ0QQsosortorderZ1QQsosortpropertyZ1
#438778 - 05/07/04 08:28 AM Re: Mustang Posi on CV's
88grandmarq Offline
4R70W rebuilder
Riigghtt, you gonna believe everything you read on E-bay?
Tell me something, since all '94 up Mustangs have 4 wheel ABS, why does this one have an ABS exciter ring mounted on the carrier?
I will tell you why, because that 31 spline carrier is from a TRUCK !
Just because somebody posts about Cobra parts, does not mean they are any different than regular production parts.
Its like all those "other" people that believe Police cars have "cop car" engines.
#438779 - 05/07/04 11:06 AM Re: Mustang Posi on CV's
Loc: Pennsylvania
They are from from an explorer and can be used on stanges with or upgraded to 31 spline axles. There are also other 31 splines from older trucks and if you go old enough several cars but i didn't include those in my post.
The cop parts is kind of funny that people make fun off.
While they laugh becuse there isn't a "cop engine".
The pi's do have a ecc tuned differently, usually a different axle ratio and the shorter ammx or aluminum drive shaft and tailshaft extension as well as different springs and shocks and rear sway bar and isn't there extra frame bracing in certain areas as well?
#438780 - 05/07/04 11:38 AM Re: Mustang Posi on CV's
88grandmarq Offline
4R70W rebuilder
Yes, I know the carrier is from an Explorer.
Thats my point... Passenger cars get 28 spline, trucks get 31 spline, end of story.
You can install a 31 spline carrier from a truck, into a car, but obviously it requires you install 31 spline axles.
This is an inexpensive upgrade for Mustang owners, Fox body cars especially, that want to go to 31 spline axles.
#438781 - 05/07/04 11:45 AM Re: Mustang Posi on CV's
Loc: Pennsylvania
ok
4 registered (ironmarinebill64, RF_Overlord, jimmyv1958, 1 invisible), 71 Guests and 291 Spiders online.
bluejay_32 162
Old_Guy_Stu 97
a_d_a_m 94
Moby_Vic 55
CrystalPistol 50
TheCableGuy 47
RF_Overlord 44
Ponyguy 39
