#450964 - 05/21/04 05:01 PM Wires under the dash
Anonymous
Unregistered
I have a 99 CVPI formerly owned by the state of North Carolina. I recently bought it, and discovered, much to my delight, that the cigarette lighter doesn't work (Echoes of The Blues Brothers.)
Anyway, I discovered that it was merely the fuse that had blown. However, when I was under the dash poking around, I discovered 2 wires coming off of the Lighting Control module. They run off of the blue and the opaque red wire and are spliced into it. The wires are cut off at another heat connector, but I assume they used to run to something. I imagine this would be for the console that at one time would have sat in between the driver and passenger front seats but am not sure. What does it do?
Second. Just for %!$#*& and giggles, I looked under the passenger side dash and found a wire with a blue clip on the end of it not clipped into anything. About 4 inches away, securely taped onto a piece of metal, is the female end of said clip. I don't want to put the 2 together without knowing what it might do. Any ideas?
Thanks!
#450965 - 05/21/04 05:17 PM Re: Wires under the dash
OpenMyThirdEye Offline
thats the dark mode plug.....
__________________________________________________
Project White - 1996 P71 Crown Victoria
"Its always better to be known by your work rather than your face" - Maynard James Keenan
2 registered (crjackson, StankBacon), 31 Guests and 280 Spiders online.
bluejay_32 223
Old_Guy_Stu 120
a_d_a_m 99
DudeAbides 91
Ponyguy 71
CrystalPistol 45
Moby_Vic 44
ClayBelt 43
Davidzq 43
Bangster 37
