#452274 - 05/23/04 01:42 PM Reverse Lights Don't Always Go On
Anonymous
Unregistered
I have an odd problem. When I shift into reverse, the reverse lights don't always go on. When shifting from park the lights almost always don't turn on but when shifting from neutral, they almost always do (almost is the key word there). What turns on the reverse lights and what should I look for to be the cause of this?
Thanks
#452275 - 05/23/04 02:03 PM Re: Reverse Lights Don't Always Go On
my96p71 Offline
Loc: USA
It sounds like Your switch is going out on the used to be on the tranny.
01 Ranger Edge 26,*** miles
96 Crown Victoria 81,5** Miles p71 Ret.L.V.M.P.D.
#452276 - 05/23/04 02:38 PM Re: Reverse Lights Don't Always Go On
specops1526 Offline
Loc: Los Angeles, CA
My '73 Mercedes 280C did that. The lights would only go on if engaged from neutral. It must be a switch in the shifter or the transmission.
2000 CVPI - Sold
1997 Land Rover Defender 90
2004 Land Rover Discovery SE
2004 Land Rover Discovery G4
#452277 - 05/23/04 08:19 PM Re: Reverse Lights Don't Always Go On
ssxty8 Offline
Loc: PR
I had to replace the MLPS($90.) on my 92 GM, not the price I imagined to solve a back up lamps failure, but check if yours is it's adjusted properly before buying a new one.
1992 Grand Marquis, 360 tinted glass, Hi/Lo Sylvania Silverstar headlamps w/home made 4ea. relay harness, smoked tail lamps and center panel, 1.5" rear spacers on original wheels with painted center spokes, Accel cool blue air filter and retrofitted dual exhaust, with original type mufflers, KYB monotube Gas-A-Just. Retrofitted TCC & A/C clutch ON/OFF switches. Wish list for the future, better fr. & rr sway bars, and poly bushings wherever possible. Much more than 300K/miles, & surprising MPG.
#452278 - 05/23/04 09:04 PM Re: Reverse Lights Don't Always Go On
Queen Victoria Offline
...going out on the used to be on the tranny.
What?
Signature removed. See rules.
#452279 - 05/24/04 02:43 PM Re: Reverse Lights Don't Always Go On
Colin Offline
Mine did that from brand new. Switch was misadjusted. I could feel the engagement through the lever. I just never cared enough to adjust it. If I needed them to come on I'd move the lever back towards P another 1/8" or so and the switch would close and turn on my lights.
#452280 - 05/24/04 05:29 PM Re: Reverse Lights Don't Always Go On
Squeek Offline
Loc: Behind you
What?
ROFL
That's what I was thinkin...
Anyway be sure to check your MLP (Manual Lever Position) sensor, which is located on the transmission. It has the shifter cable running through it. It's likely that's either loose or bad. I got mine for $27.
Good Luck!
#452281 - 05/26/04 03:46 PM Re: Reverse Lights Don't Always Go On
Bell Offline
This also happened when i first got my car, but it hasn't done it in a long time.
4 registered (Davidzq, WiGe, ford05, Freddy12189), 58 Guests and 169 Spiders online.
bluejay_32 194
a_d_a_m 141
Old_Guy_Stu 125
DudeAbides 90
Ponyguy 64
Davidzq 47
Moby_Vic 45
LTC_Dave 39
ClayBelt 37
