#507258 - 08/02/04 03:25 AM 197 Degree Thermostat???
gsn2984 Offline
Loc: Manchester, CT
I was at autozone the other day and going to pick up a new thermostat when I take off my upper tube to replace it, and they said that normal for the 5.8 is a 197 degree thermostat. I was just wondering if this is what I should use, or should I go with a 180.
Also, I was going to put one of those chrome housings for the thermostat but on mine, there is an extra hole it it where it almost looks like a vacuum line and then goes somewhere under the carb. Its late and I can't remember what it exacly looks like. But any help on the first questions would be greatly appreciated. Thanks beforehand.
1992 Ford Crown Victoria S P72 ex CT officers car.
Yes, my avatar is a Lego CV with engine and full working front and rear wigwags!
Cardomain page for old 89
#507259 - 08/02/04 03:31 AM Re: 197 Degree Thermostat???
85crownHPP* Offline
Loc: central VA
I have a 180 and we feel much cooler
Pete ::::>>> resident LED addict and CFI defector
My rant on LED bulb replacements
'91 Crown Vic (badass beater) . '85 LTD Crown Vic (HPP project) . '88 P72 (ODB)
85HPP's mods:
CFI to SEFI conversion w/ HO upperstuff - headers & flowmasters - p71 airbox - Towncar seats - LED dash light-show - center gauge console - LED 3rd brake light - 3G alternator - mini starter - washer/coolant bottle upgrade - Towncar power trunk pull - underhood fuse/relay box - police swaybars w/poly rubbers - painted HPP wheels - 600W RMS Alpine driven 10-speaker stereo
#507260 - 08/02/04 03:59 AM Re: 197 Degree Thermostat???
PhAyZeR5 Offline
Loc: Dunnellon, FL
I've never heard of a 197. I used a 180 when I cas CFI'd and now, with no problems.
My lugnuts take more torque than your Honda puts out
408w powered Cobra Linc
#507261 - 08/02/04 04:10 AM Re: 197 Degree Thermostat???
gsn2984 Offline
Loc: Manchester, CT
The weird thing is, that even on their website it says: "ORIGINAL EQUIPMENT TEMPERATURE. " But of course, like I said, this is for a 5.8.
#507262 - 08/02/04 04:30 AM Re: 197 Degree Thermostat???
Petely Offline
Loc: Chicago, IL
It should be 195 I believe. A couple of degrees is nothing to argue about when you are dealing with those kinda temps. A lot of people run a 180 deg but I don't think you want to run much cooler then that. I would like to know when the cold idle circuit kicks off becuase that will help you guage how low you can go without risking staying in the cold loop.
Peter
1987 Mercury Grand Marquis
*sold to some guy on cvn for $1
New Long List of Rules Compliant Sig
#507263 - 08/02/04 09:42 AM Re: 197 Degree Thermostat???
1987LTDmasta Offline
Loc: Chicago, IL.
195 is actually the OEM version
get a 180 and forget about it. 180 is the coldest I reccomend since the engine goes into CLOSED loop at 150 degrees
she gone.
5.0 liter EFI High Output
Police Package suspension
Current:
'67 Mustang coupe
#507264 - 08/02/04 12:01 PM Re: 197 Degree Thermostat???
gsn2984 Offline
Loc: Manchester, CT
I got the 197 anyway plus the gasket. I don't mind running a little warm, it stays pretty good anyway because of a new fan clutch and no friggin condensor in the way. Thanks for all the input.
2 registered (bluejay_32, Traffic22), 61 Guests and 269 Spiders online.
bluejay_32 166
a_d_a_m 105
