#530059 - 08/31/04 07:29 PM
window problem
Loc: Dallas, TX
Today my front right window made a loud cracking sound as it was closing and then it stopped alogether, and now it does not work at all. I found two pieces of broken white plastic on the bottom of the door well after taking apart the door, and the silver metal cable was dangling. The glass is fine.
The guy at the Ford Parts counter said a piece of routing plastic from my regulator has broken off and he showed me how to put on a new one. It costs $89 for the regulator, and one of the mechanics offered to come over and install it for me for $50 if I did not want to hassle with it, and I'm inclined to have him do that.
But first I thought I'd ask if anyone has a better idea, or if perhaps I can avoid paying $89 for the regulator. My thinking is that a junkyard regulator isn't a good bet since if the palstic tends to break anyway, why get an old one that wil just break sooner. Thanks.
dark blue 1997 P71, 160k, 21mpg white 2000 P71, 93k, 19mpg
#530060 - 08/31/04 09:26 PM
Re: window problem
Loc: Louisville, KY
Window Regulators sell new on ebay for $29.99 http://search.ebay.com/crown-vic-window_W0QQsokeywordredirectZ1QQfromZR8Where I bought my car, he charges $25 to install. You CAN do it yourself, there's alot to do because you have to take off so much stuff, drill out somethings to get to the screws, etc. I've seen it done 3 times.
#530061 - 08/31/04 11:56 PM
Re: window problem
My driver door one made the same sound and now does not work. Could it be my motor? Or just the regulator? My dad said my motor was gone and have to replace it.
'03 300A #1801. Vortech NOIC #5 - 445rwhp/408rwtq on 9lbs. Tuned by Outlaw Dyno
#530062 - 09/01/04 12:01 AM
Re: window problem
Loc: Louisville, KY
If you hear the crackling sound, it is the regulator. The crackling sound is the cable twisting and bunching up.
The motors are RARELY the culprit vs the regulator.
#530063 - 09/01/04 12:03 AM
Re: window problem
Ahhh I see then, yep, I heard a loud crunching sound, it went up all the way, went down about two inches, and never came back up, had to pull it up with my hands. Thanks for the info though, here I was going to get a whole motor.
#530064 - 09/01/04 12:14 AM
Re: window problem
Loc: Louisville, KY
I've had two windows fail. drivers left and drivers right (this is ford confusion for drivers and drivers rear)
I rolled down the windows to the car when pulling it up to the garage to get it fixed.. crunch the drivers rear failed broke right there.
You need a drill because there are some "buttons" you have to drill out so you can access the screws. You will also have to remove all door trim (even the exterior piece) as this makes it possible later to actually remove the window (yes you have to). I can almost do it by memory but need to be looking at the door. (visual person)
#530065 - 09/01/04 12:21 AM
Re: window problem
lol, I'm going to have my cousin's garage put it on for me. I have heard stories where if you're not careful with the window, there is some sort of blade that can cut your hand? Is this true?
#530066 - 09/01/04 12:40 AM
Re: window problem
Loc: Michigan
defentially a Window Regulator, *thinks back to when his broke* I remember the plastic, wrie, etc all too well cause I thought it was just the motor and tried so many times to put it back togather, it just won't happen.
Now for the blade theory I don't know if anything ready to jump out and cut you unless you broke the glass or started reaching around looking for a sharp object
Previous Panthers Grand Marquis 1986, 1993 Crown Victoria 1994, 1998
#530067 - 09/01/04 09:32 AM
Re: window problem
Loc: Dallas, TX
Thanks, I just now bought the ebay regulator, now I have to get it installed. The mechanic at Ford said it would take him 20 minutes but Ford would charge me and arm and a leg - then his bud at the counter gave me the number of this independant joe who said he'd do it for $50. But if it is an easy job (for an experienced person) maybe $25 is possible.
The question is how do you find independant guys who work cheap? I called my local shop and they quoted me $70. There wouldn't be by any chance someone here who wants a little freelance work? (in Dallas)
#530068 - 09/01/04 05:50 PM
Re: window problem
Loc: Louisville, KY
Where do you live? I'm in Louisville KY
The guy I bought my P71 from did mine. He is in Ky south of Louisville. I could maybe create and article on how to do it but I have to use pictures.
#530069 - 09/01/04 07:20 PM
Re: window problem
Loc: Grand Rapids, MI
I found it to be a very simple job, took me less than a half hour
Dead: 1994 Crown Vic LX/HPP... over 190,000 miles when she got totalled  Gone: 1996 Mustang GT 5spd, drop top, Bassani OR X-pipe, Dynomax Ultraflows, PI Cams, K&N FIPK, C&L Elbow and 75mm TB, PIAA 1700X... Dead: 2012 Mustang V6 Performance Package, Kona Blue with MagnaFlow "Street" catback. KIA August 2012
#530070 - 09/01/04 07:39 PM
Re: window problem
Go to lincolnsonline.com/article11.html and see how to do it. fwiw, but even if ya screw it up, you can always drive it to a shop and let them do it....just dont lose any parts(screws, nuts,etc.)
#530071 - 09/01/04 07:41 PM
Re: window problem
Go to lincolnsonline.com/article11.html and see how to do it. fwiw, but even if ya screw it up, you can always drive it to a shop and let them do it....just dont lose any parts(screws, nuts,etc.) Oh, forgot to mention its in their 'tech' section.
#530072 - 09/01/04 07:44 PM
Re: window problem
Loc: Louisville, KY
That's a great and lengthy article.. but if you are like me.. without pictures I would be lost.
#530073 - 09/01/04 07:57 PM
Re: window problem
Try article27 then, its for the rear but they are similar...www.lincolnsonline/article27.html fwiw and they gots pics for ya to boot
