#530256 - 08/31/04 11:01 PM power window
bigskiohio Offline
92 cv window wont work but motor is working i can hear it.
will replacing the nylon dowels or gear work on this year.
#530257 - 08/31/04 11:02 PM Re: power window
Buck268 Offline
Loc: Grand Rapids, MI
Well, if you searched, you would have found this to be an extrmely common problem.
*HINT* Its the window regulator. Replace it.
#530258 - 08/31/04 11:05 PM Re: power window
bigskiohio Offline
Well i did search and i figured it was the regulator but the question was will the nylon dowels help or not?
#530259 - 09/01/04 12:02 AM Re: power window
Colonel Offline
Loc: Louisville, KY
no just buy the daggone $30 regulator new on ebay.
Quad-Cam Cop Engine, Bullet Proof Tires & Windows, Stab Proof Seats, Steel Door Beams, SuperCharger, Anti-Deer Harmonic Wheel Covers, Trunk Mounted Counterbalance System
..and many other things people told me my car is equipped with.
#530260 - 09/01/04 12:31 AM Re: power window
ssxty8 Offline
Loc: PR
IMO, you'll never know 'til you inspect whats wrong inside the door. In my case, I had to replace the front driver's and rear driver's nylon inserts. Better yet, I made my own from delrin. Now, I just have to be careful and don't force the windows past their operating range(up/down resting position). They have worked for more than a year now.
1992 Grand Marquis, 360° tinted glass, Hi/Lo Sylvania Silverstar headlamps w/home made 4ea. relay harness, smoked tail lamps and center panel, 1.5" rear spacers on original wheels with painted center spokes, Accel cool blue air filter and retrofitted dual exhaust, with original type mufflers, KYB monotube Gas-A-Just. Retrofitted TCC & A/C clutch ON/OFF switches. Wish list for the future, better fr. & rr sway bars, and poly bushings wherever possible. Much more than 300K/miles, & surprising MPG.
#530261 - 09/01/04 11:35 PM Re: power window
DreadfullyDespized Offline
Loc: Hutchinson, MN 55350
so if the window doesn't move and the motor is making noise and you can manually push the window up and down that also the window regulator problem?
DD Security Inc.
Console modding/electronics repair/Airsoft
#530262 - 09/02/04 01:07 AM Re: power window
Colonel Offline
Loc: Louisville, KY
yes
the window regulator is the cable and shaft system that moves the window up or down.
you can see the picture on ebay under search: crown vic window
the motor attaches to that cable pulley.
3 registered (Denal, TheShadow, TheBestNeverRest), 66 Guests and 28 Spiders online.
