#532191 - 09/03/04 02:59 PM
Trunk Won't Stay Open
Loc: Michigan
So back when I went on that little road trip last week in the first few minutes of driving all heard a loud bang of metal so I pull over to investigate it and find out the trunk won't stay open but itself anymore, There any way to fix this? I can't see what is broke. It's slightly annoying to have to hold it and it is more heavy that one would think.
Previous Panthers Grand Marquis 1986, 1993 Crown Victoria 1994, 1998
#532193 - 09/03/04 03:45 PM
Re: Trunk Won't Stay Open
 Torsion Bar Loading WARNING: Safety glasses must be worn when performing this operation. NOTE: The luggage compartment door tension should be decreased if the luggage compartment door opens with more force than desired. The luggage compartment door tension should be increased if the luggage compartment door opens with less force than desired. Open and support the luggage compartment door in the full-open position. WARNING: Use care when adjusting the luggage compartment door/tailgate hinge torsion bar (44891). It is under tension and could spring out of control if it is not handled properly. Move the luggage compartment door end of the luggage compartment door/tailgate hinge torsion bar to another position. Check the adjustment. WARNING: Use care when adjusting the luggage compartment door/tailgate hinge torsion bar. It is under tension and could spring out of control if it is not handled properly. Move the luggage compartment door end of the luggage compartment door/tailgate hinge torsion bar to another position.
1997 P71 145K miles
#532195 - 09/03/04 04:57 PM
Loc: Michigan
Thanks for a new challenge
#532196 - 09/03/04 05:01 PM
Loc: Regina, Saskatchewan
Oh man, you have a problem with your truck not staying open. Mine opens all the time. I'll just be driving and it will pop open and then the wind will catch it and just fling it all the way open.
2000 P71 stock...
#532199 - 09/06/04 11:29 PM
Loc: Michigan
I looked at it yesturday while up north and one of the metal bars is broke in a few pieces so It looks like I just need to replace the bar but you won't belive how hard it has been to find any 92-97 vic's in my area in junk yards.
#532203 - 09/08/04 11:42 AM
Loc: Michigan
I have that movie! It's so funny, I would think you may want to turn the tension down and make sure the latch is in good condition.
#532204 - 09/08/04 03:25 PM
Awesome, thanks for the info. I'll try that this weekend.
2000 P71 stock...
#532205 - 09/08/04 03:37 PM
Loc: Ft. Wayne IN
All my other cars were not to hard to adjust. THe vic was a [email protected] It took two guys with a tow strap pulling on it to get it in the last slot. :shudders:
1995 Town Car, flowmaster 50's, gutted cats, gutted evap system, cold air tube, MMairbox & 80mm maf, K&N air filter, DR chip, 180 thermostat, 22pp plugs, Steeda underdrive pulleys w/gatorback belt, transgo shift kit, cross-drilled rotors w/performance friction pads, addco swaybars front and rear, poly bushings, edelbrock IAS shocks all around, deleted mechanical fan, Kenwood MP4028 w/kenwood 6x9's and 6x8's and more to come
1982 Crown Vic LTD 2dr No air pump or cats, cragar ss's, dual exhaust, tach, volt, oil, temp gauges.
