#532191 - 09/03/04 02:59 PM Trunk Won't Stay Open
tbug Offline
Loc: Michigan
So back when I went on that little road trip last week in the first few minutes of driving all heard a loud bang of metal so I pull over to investigate it and find out the trunk won't stay open but itself anymore, There any way to fix this? I can't see what is broke. It's slightly annoying to have to hold it and it is more heavy that one would think.
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#532192 - 09/03/04 03:13 PM Re: Trunk Won't Stay Open
Liquid Offline
RWD V8
Loc: World's Motor Capital
Sounds like one of your torsion rods got knocked out of its slot. I will try to remember to get pics of my torsion rods and post them later, if you haven't figured it out by then.
NedP1, you are missed!
#532193 - 09/03/04 03:45 PM Re: Trunk Won't Stay Open
observer Offline
Torsion Bar Loading
WARNING: Safety glasses must be worn when performing this operation.
NOTE: The luggage compartment door tension should be decreased if the luggage compartment door opens with more force than desired. The luggage compartment door tension should be increased if the luggage compartment door opens with less force than desired.
Open and support the luggage compartment door in the full-open position.
WARNING: Use care when adjusting the luggage compartment door/tailgate hinge torsion bar (44891). It is under tension and could spring out of control if it is not handled properly.
Move the luggage compartment door end of the luggage compartment door/tailgate hinge torsion bar to another position.
Check the adjustment.
WARNING: Use care when adjusting the luggage compartment door/tailgate hinge torsion bar. It is under tension and could spring out of control if it is not handled properly.
1997 P71 145K miles
#532194 - 09/03/04 03:52 PM Re: Trunk Won't Stay Open
BK_Grand_Marquis Offline
Loc: NJ
I ran into this problem not too long ago. The rod snapped on the right side. I had to get it replaced. The part is about $20. It was a pain to install. It took me about 10 tries and two days before I could find the right way to put the rod back on without it snapping back at me. I still have the old one as a souvenir of all the pain it caused me.
SuperMotors Page
Central Jersey Mustangs and Fords
Best 1/4 Mile:15.195 @ 89.79 mph - 2.207 60' - 11/03/06
Project Car - 1990 Mustang LX Hatchback
#532195 - 09/03/04 04:57 PM Re: Trunk Won't Stay Open
tbug Offline
Loc: Michigan
Thanks for a new challenge
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#532196 - 09/03/04 05:01 PM Re: Trunk Won't Stay Open
Sabotage Offline
Loc: Regina, Saskatchewan
Oh man, you have a problem with your truck not staying open. Mine opens all the time. I'll just be driving and it will pop open and then the wind will catch it and just fling it all the way open.
2000 P71 stock...
#532197 - 09/03/04 05:02 PM Re: Trunk Won't Stay Open
tbug Offline
Loc: Michigan
Which is worse?
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#532198 - 09/03/04 05:13 PM Re: Trunk Won't Stay Open
Raptor9458 Offline
Loc: Chicagoland
Which is worse?
The trunk popping open while driving.
I've been considering increasing the tension on mine. With the added weight of the antennae, cables, strobes, etc., the lid sags a little. It just seems like a bit of a pain to deal with those rods.
#532199 - 09/06/04 11:29 PM Re: Trunk Won't Stay Open
tbug Offline
Loc: Michigan
I looked at it yesturday while up north and one of the metal bars is broke in a few pieces so It looks like I just need to replace the bar but you won't belive how hard it has been to find any 92-97 vic's in my area in junk yards.
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#532200 - 09/07/04 07:45 PM Re: Trunk Won't Stay Open
Raptor9458 Offline
Loc: Chicagoland
Plenty of '97 and older in the yards around here, it's almost impossible to find the '98+ though. Everyone is holding on to them. There's a taxi repair shop I pass that has about twenty or so totaled '98+ vics, and the CPD boneyard is full of them as well, too many to count.
#532201 - 09/07/04 11:20 PM Re: Trunk Won't Stay Open
tbug Offline
Loc: Michigan
I may be out that way, The gas smell is making me sick again so If I can't figure it out I'm not going to be motivated to fix anything on the car because it will still try to kill me
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#532202 - 09/08/04 05:00 AM Re: Trunk Won't Stay Open
Sabotage Offline
That reminds me of that movie Maximum Overdrive starring Emilio Estevez. Crazy trucks trying to kill people. With my trunk popping open just at random times, is there anything to fix that? I don't know too much about that, would it be the latch? Or is it possible that something in my trunk is catching the anti-kidnap trunk release safety cord thing?
P.S. Sorry if this is off topic.
2000 P71 stock...
#532203 - 09/08/04 11:42 AM Re: Trunk Won't Stay Open
tbug Offline
Loc: Michigan
I have that movie! It's so funny, I would think you may want to turn the tension down and make sure the latch is in good condition.
Previous Panthers
Grand Marquis
1986, 1993
Crown Victoria
1994, 1998
#532204 - 09/08/04 03:25 PM Re: Trunk Won't Stay Open
Sabotage Offline
Awesome, thanks for the info. I'll try that this weekend.
2000 P71 stock...
#532205 - 09/08/04 03:37 PM Re: Trunk Won't Stay Open
p71towny Offline
Loc: Ft. Wayne IN
All my other cars were not to hard to adjust. THe vic was a bi@ch. It took two guys with a tow strap pulling on it to get it in the last slot. :shudders:
1995 Town Car, flowmaster 50's, gutted cats, gutted evap system, cold air tube, MMairbox & 80mm maf, K&N air filter, DR chip, 180 thermostat, 22pp plugs, Steeda underdrive pulleys w/gatorback belt, transgo shift kit, cross-drilled rotors w/performance friction pads, addco swaybars front and rear, poly bushings, edelbrock IAS shocks all around, deleted mechanical fan, Kenwood MP4028 w/kenwood 6x9's and 6x8's and more to come
1982 Crown Vic LTD 2dr No air pump or cats, cragar ss's, dual exhaust, tach, volt, oil, temp gauges.
Traffic22 15
