#534130 - 09/06/04 03:40 PM
What fluids do you use?
Thought it would be interesting to see what everyone is using in their cars as far as brand, weight, octane, etc. No discussion please as people are very loyal to their lubes and it will turn into a 50 page long thread about why running brand X gas will make your car eat ferraris for lunch and why brand Y brake fluid will make it explode into a ball of fire.
I'm using-
Oil:Mobil 1 5w30 synthetic
Oil Filter:K&N
Coolant: 50/50 distilled water, Ford coolant, water wetter
ATF: have yet to change
Differential: have yet to change
Brake Fluid: have yet to change
Gas: any brand name 93 octane
2001 Crown Vic P73 Base Model 68,000 miles
#534131 - 09/06/04 03:49 PM
Re: What fluids do you use?
That is why there so many brands.
Everyone is free to use what they want.
#534132 - 09/06/04 03:56 PM
Loc: Motor City, USA
Oil: M1 5W-30 and M1 15W-50 mixture Oil Filter: Motorcraft FL-820S Coolant: 50/50 Prestone Green and Distilled ATF: Castrol Mercon-V Differential: Redline 75W-90 Brake Fluid: Borg Warner DOT 4 Gas: Sunoco 89 octane Windshield Wiper: Rain-X Winter Power Steering: Mercon-V ATF
#534133 - 09/06/04 04:51 PM
Loc: Wakefield, Massachusetts
Mobil 5w-30 dino engine oil Ammaco Mercon V tranny fluid
#534134 - 09/06/04 05:56 PM
exactly, but instead of reading through a bible's worth of why this is the best and that oil sucks, thought it would be interesting to just let who uses what speak for itself in a simple to read form
#534135 - 09/06/04 06:00 PM
Loc: Denver, Colorado
Engine Oil- Mobil-1 10W30 synthetic Changed every 5000 miles Engine Oil Filter- AC/Delco Coolant- Whatever my service garage used, probably Prestone 50/50 (green stuff) ATF- Same brand that vehicle came from factory with, did fluid and filter change at 120,000 miles and change solved shudder problems and have not had any shudder to this day since. Differential- No idea what they put in it when they serviced it at 120,000 miles. Brake Fluid- had system flushed at 125,000 miles, not sure what brand they used. Gas- Phillips 66, Diamond Shamrock, or Amaco/BP 85 Octane, never needed anything higher, vehicle doesn't run very well on 87 or 91 octane, 85 does just fine up here at high altitude.
1996 P71
#534136 - 09/06/04 09:59 PM
Loc: Coon Rapids MN
oil: castrol gtx synthetic Engine oil filter: Motorcraft coolant: prestone 50/50 green stuff ATF: Mercon v tranny fluid Gas: 87 from all gas stations
2012 Ford F150 Ecoboost
RIP 99 CVPI
#534137 - 09/06/04 11:35 PM
Anonymous
Unregistered
OIL: CASTROL GTX
OIL FILTER: IDK...THE 2ND BEST ONE AT PEP BOYS..PUREONE..BUT ITS THE BETTER MODEL...$5
#534138 - 09/07/04 12:02 AM
oil=10w30 mobil 1 synthetic both car's now..
Trans oil = mercon
rear end= super tech 75 w90
1993 LX mod's a snorkel,dual exhaust and 3:55 gear's now. 1999 Trans am with ram air hood. LS1 mod's 3:73's exhaust cutout's, hypertech programer and a Nx gas 100 shot wet kit with window switch. Ya it's bad a s s!!
#534139 - 09/07/04 12:12 AM
Tech Admin
Loc: Socialist state of MN
Amsoil 5W-30 FL-1A Amsoil ATF Amsoil Syn gear oil NAPA panel air filter Goodyear or Motorcraft belts Motorcraft hoses 91 Octane NON-Oxygenated fuel (I would use 87 but it's not offered in non-oxy formulations).
#534140 - 09/07/04 12:23 AM
Loc: Louisville, KY
Oil: 10w30 Mobil 1 Oil Filter: Motorcraft 820s ($2 walmart) Coolant: some water and some green stuff ATF: some red stuff Differential: ________ Brake Fluid: Napa Heavy Duty something Gas: Chevron 87 octane Wiper Fluid: Rain-X Blinker Fluid: KaleCo Auto Synthetic Air Filter: STP
#534141 - 09/07/04 12:58 AM
nice!
-Current: 2001 Crown Victoria P74  -Gone, but not forgotten: 1988 Mercury Grand Marquis 1994 Ford Crown Victoria 2000 Ford Crown Victoria HPP 2004 Ford Crown Victoria LX Sport 2004 Mercury Grand Marquis
#534142 - 09/07/04 01:01 AM
Loc: Louisville, KY
Thanks, I always use synthetic when available!
#534143 - 09/07/04 03:34 AM
Oil: Royal Purple 10W-30 synthetic Oil Filter: Motorcraft FL-820S (best filter out there for the money) Coolant: Premixed 50/50 Prestone green stuff ATF: Motorcraft Mercon V from the dealership Differential: Royal Purple 75W-90 (w/ NAPA Victor Reinz gaskets exclusively) Brake Fluid: SuperTech DOT-3 P/S Fluid: Will be switching over to Royal Purple in the near future Gas: Not terribly picky. Usually Shell, Mobil, or Chevron if possible...but always 87 octane.
Signature removed. See rules.
#534144 - 09/07/04 12:12 PM
Loc: Clearwater, FL
Oil - Amsoil ASL 5W30 / XLM 5W20 Blend Filter - Asmoil SDF 11 Trans - Amsoil ATF Trans filter - Hastings TF-128 Diff - Amsoil TGR Series 2000 75W90 gear lube.
2002 CV LX Sport - Bone stock, for now ;-) except for Amsoil lubes of course. 10W30 ATM engine oil, Amsoil ATF in the tranny, and Series 2000 75W90 gear lube in the diff. Kuhmo Ecsta KH 11 tires. Ford Motorsport Dual Mode Mufflers. 15.87 1/4 mile ET. www.lubedealer.com/dstevens
#534145 - 09/09/04 05:17 PM
Oil-Castrol GTX 20W50(in the summer)plus Lucas oil stabilizer Filter- MotorcraftFL820-S Trans-Napa brand Mercon with Lube Gaurd additive Rear-Red Line synthetic gear lube Coolant-Napa brand, H20 Brake-Valvoline brand heavy duty DOT3 Windshield-Splash! brand straight Blinkers-BF brand, dry sump system
1993 GM LS 243k miles 29.5mm PI front bar(ENS greaseable poly bushings),21mm HPP rear bar(ENS poly bushings/endlinks),Mechanical Stewart-Warner oil pressure gauge. Black steelies/center caps...K&N filter
1994 Lincoln Mark VIII 144k miles All airbags switched to coils/struts, junk tranny, motor donor car Mercury Owners Group
This is a disclaimer: This post is the opinion of the person in question. It is presented as nothing more than that. Furthurmore, this opinion is is not necessarily the opinion of CVN, any of its affiliates, or anyone else on Earth.
#534146 - 09/09/04 06:13 PM
Oil - AMSOIL 10w30 ATM Oil Filter - Supertech Trans - haven't changed it yet, should do it soon...then AMSOIL Coolant - Prestone Diff - AMSOIL S2k 75w90
I'm Dark, I'm Dan....I'm Darkdan.  98 CVPI With A Black Grill! Southern MN's Cheapest (and 2nd worst) window tinter! 3M Paint Protection Film!
#534147 - 09/09/04 07:23 PM
Loc: N.O.LA.
Oil: M1 5W-30
Coolant: 50/50 Prestone Green and Distilled, Yellow in '04.
Differential: M1 75W-90
Fuel: Chevron - 87 octane lately - will flip chip back to 93 soon.
Power Steering: Castrol Mercon V ATF
Owner: Today - Bass Ale - after got home.
JAM
1998 GM LS HPP+(Gone 3/09) 2004 LX Sport 2009.5 G8 GT
#534148 - 09/09/04 07:27 PM
Loc: Louisville, KY
Why are you people using Rain-X Winter in the summer? Winter has de-icer and summer has bug remover.. soo... ?
#534151 - 09/09/04 09:35 PM
Loc: Louisville, KY
I got through two big bottles of rain-x washer fluid each season atleast
1 registered (Rainbowpizza),
39
221
