#535241 - 09/08/04 03:20 PM
Re: Police Interceptor Computer
Loc: Louisville, KY
It doesn't remove the speed limited, tho, does it?? Maybe one of those doohickies that plugs into the OBD2 port would help with that. .
Speed limiters on civvy vics is about 112mph. This is because of the driveshaft.
Police vics have a speed limiter of 135 (+/-) BUT, they have the "police" driveshaft that can handle the resonance/vibrations of those higher speeds (IIRC)
So yes, he will be able to go faster, WHY! but he may also pole-(driveshaft)-vault his car.
#535243 - 09/08/04 07:21 PM
I thought that there was a crossmember that prevented the front of the driveshaft from falling down. At least that's how it is on my '93 GM. This would allow the back to fall, but not the front. Am I correct on this?
1993 GM LS 243k miles 29.5mm PI front bar(ENS greaseable poly bushings),21mm HPP rear bar(ENS poly bushings/endlinks),Mechanical Stewart-Warner oil pressure gauge. Black steelies/center caps...K&N filter
1994 Lincoln Mark VIII 144k miles All airbags switched to coils/struts, junk tranny, motor donor car Mercury Owners Group
This is a disclaimer: This post is the opinion of the person in question. It is presented as nothing more than that. Furthurmore, this opinion is is not necessarily the opinion of CVN, any of its affiliates, or anyone else on Earth.
#535245 - 09/08/04 11:42 PM
Loc: Louisville, KY
You voted for the top speed limiter before you voted against it. You dont want to get close to the top speed but want the car to go faster and want to beat your buddy's S10. (street racing? I would assume, because you won't get close to 103 or 112mph drag racing)
#535246 - 09/09/04 12:31 AM
he probably only has a 3.27 rear end, steel shaft. I would at least put a regular aluminum shaft on it to run the 130 dept.
Signature removed. See rules.
#535247 - 09/09/04 12:35 AM
Loc: Who wants to know...
Close Colonel, Just a matter of bragging rights  , besides I don't plan on running the car faster than 120, if I did I wouldn't know how fast I was going. How fast are the Panthers properly tuned with a supercharger kit in the 1/4?
I try not to take things personally... Everyone's a person, how else are they supposed to take it? 'The portal to hell is opened with the incantation of good intentions'
