#535695 - 09/08/04 07:32 PM
Re: Where's My Jack
A floor jack works fine.
Don't jack it up by putting it under the center of the differential or cross member in the front. That is forbidden in the owner's manual.
#535696 - 09/08/04 07:39 PM
Re: Where's My Jack
Loc: Michigan
I got a floor jack in mine also, come in handy many many times and susprised people because they don't belive I would carry such a thing.
Previous Panthers Grand Marquis 1986, 1993 Crown Victoria 1994, 1998
#535698 - 09/09/04 04:26 PM
Re: Where's My Jack
What do you mean by floor jack? If it is one of those long things that you roll around, you are both nuts. You could fit at least a case of beer in that space. Mudbone, if it is not under the spare or behind the "carpet" on the right side, you can pick one up in a salvage yard.
'99 GM GS HPP. I may not be a rocket scientist, but I *am* a scientist.
#535700 - 09/09/04 05:43 PM
Re: Where's My Jack
I wish I knew that before (no manual). are you supposed to jack it up by the pinch weld or the frame? Any idea why it's forbidden?? (I guess you could snag the sway bar in the rear)
#535702 - 09/10/04 12:11 AM
Re: Where's My Jack
Loc: Worcester, MA
Mines right next to the case of beer...in the P71 and the P74 LOL
2000 P71 Deep Wedgewood Blue 2004 Ford CV P74 Sport
#535703 - 09/10/04 01:46 AM
Re: Where's My Jack
Loc: Waldorf, MD
Mine's wedged under donut spare.
A bottle jack will be a pain. if it's tall enough to lift the tire off the ground, it wont fit under the frame rail (esp if you have a flat), and the lift head will bend the bottom of your frame rails.
99 CV Deep Wedgewood Blue 12.947 @ 104.05 00GT PI 4.6l engine; 24# injectors; 190 lph intank pump; Marauder MAF; 75mm BBK t/b; Trick Flow Upper intake; SCT ProRacer Flasher; Performance Automatic AODE valvebody; Underdrive pulleys; 3.73 FRPP gears and Mustang Trak-lock; Level Ten 3000rpm converter; Ford shorty headers cut and welded to fit; 2.5" cat-back with X, high flow cats; NOS 05-171 4.6L Dry kit; 245/55/16 Toyo Proxes T1-S on 16" '95 CobraR replica rims.
#535704 - 09/10/04 04:54 AM
Re: Where's My Jack
Anonymous
Unregistered
the jack in my 98 is behind the carpet on the right side of the trunk
